Old 08-31-2007, 01:33 AM   #1
Chambers
Chambers's Avatar
Question Clutch Compatibility Question
Hi all, are the clutches for the R154 tranny compatible with a W58 tranny clutches? Thanks.
Old 08-31-2007, 01:38 AM   #2
oowee623
oowee623's Avatar
oowee623 is on a distinguished road
yes, just not the pressure plate
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
oowee623 is offline   Reply With Quote
Old 08-31-2007, 01:50 AM   #3
Chambers
Chambers's Avatar
Question
Ok, thanks! But what if I had a flywheel for the R154, does the R154 flywheel have the same number of teeth and the same bolt pattern as the W58 flywheel? Thanks again.
Old 08-31-2007, 03:40 AM   #4
oowee623
oowee623's Avatar
i think its the same since its the same block, and i checked an auto parts store like autozone and na and turbo had the same part numbers so yeah i guess the clutch and flywheel are the same, the 1jz flywheel is different for sure cause it has 8 instead of 6 bolts
Old 08-31-2007, 01:36 PM   #5
Chambers
Chambers's Avatar
Ok, that works, Thanks.
Clutch wear question suprabahamut Non-Generation Specific Questions 2 09-14-2008 04:20 PM
Clutch Master Cylinder question. 1989 Supra. PFlanagan MKIII Supra 4 08-07-2008 08:20 PM
clutch question !! 88Supra86 MKIII Supra 5 09-26-2007 01:47 AM
Flywheel and clutch question Jrok25supra MKIII Supra 8 09-05-2005 07:29 AM
