Old 08-29-2007, 11:32 PM   #1
teedoff00
teedoff00's Avatar
teedoff00 is on a distinguished road
Default Oil Pan Leaking!
I finished my turbo swap about three months ago and so far everything is great. However, my oil pan is leaking out the front end. I have taken it off and tried to re do it three times. The next will be the forth. The first and second times I used fel-pro gaskets and copper rtv hi-temp silicone. The last time (after consulting the toyota dealer) I used the black toyota fipg. Still no luck is there some trick I should be doing? HELP please!! This leak is driving me crazy, not to metion gumming up my once clean undercarriage.
Thanks
teedoff00 is offline   Reply With Quote
Old 08-30-2007, 12:53 AM   #2
supradaddy0803
supradaddy0803's Avatar
Did you check to see if the flange was flat like it is supposed to be. A little bent spot will cause it to leak like crazy no matter how much you try to seal it. The reason is when you tighten it down it will pull away from the RTV and leak. Also I would check to make sure there isnt a crack somewhere. Because if you filling it with a ton of RTV and it is still leaking that seems to be a big flag to me.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 08-30-2007, 02:15 AM   #3
Cool
you might want to make sure it's really the oil pan leaking
and not the cam seals leaking down the front and looking like it's the oil pan leaking
like the master charge commercial
toyota supra manual $100.00
toyota supra parts $125.00
toyota supra experience priceless
Old 09-01-2007, 11:54 AM   #4
IHateHacks
IHateHacks's Avatar
I agree, its either a warped sealing surface on the oil pan or the front main seal is leaking which is behind the timing belt crank sprocket and is not fun to replace.
valve cover gaskets are leaking D_Train MKIII Supra 18 03-19-2015 04:53 PM
Leaking Oil 94TT MKIV Supra 7 10-29-2014 12:41 PM
Oil Is Leaking I Have Pics!! Need Help!! Ahmad88 Non-Generation Specific Questions 18 07-09-2006 03:56 PM
water leaking from A/C inside car Ron90Turbo MKIII Supra 2 09-12-2005 04:31 AM
leaking oil 87supraguy MKIII Supra 3 03-31-2005 11:15 AM
