Old 08-24-2007, 09:03 PM   #1
ceelo9031
ceelo9031 is an unknown quantity at this point
Default 2jz gte
Could a 2jz gte fit in my 1992 supra?
ceelo9031 is offline   Reply With Quote
Old 08-24-2007, 11:43 PM   #2
supraman121
yup but with alot of work, it would be cheaper and easyer to put a 1jz in your car, it should bolt right in cause they changed the engine mounts in 89 to accomidate the 1jz so it should fit in, you would need the wireing harness and ecu, same with a 2jz swap and the bellhousing for that motor so your transmission will work. But i would go with the 1jz. Cheaper.
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 08-25-2007, 06:57 AM   #3
supradaddy0803
supradaddy0803's Avatar
Yup supraman's got it much cheaper to put the 1jz in because it was made for the mark 3 supra. Lots of mods you have to make to the 2jz to make it fit and also a 1jz is cheaper to buy than a 2jz so it is all around a better deal. Plus the 1jz makes your car mad fast I love mine.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 08-25-2007, 01:49 PM   #4
supramacist
supramacist's Avatar
How many hp does the 1jzgte put out???
I keep hearing all kinds of numbers and I just mean stock no mods.
Ya, I keep hearing from 250hp to 480hp.
Old 08-25-2007, 04:51 PM   #5
supradaddy0803
The 1JZ puts out 280 at the flywheel and about anywhere from 250 to 260 at the wheels. With the few things I have done to my car I am getting 270 at the wheels on 11 psi. The factory psi is 10 but I am afraid to turn it up because I havent got a wideband yet and you never know what might happen. Also I am planning on getting a Greddy e-manage ultimate then its on I know the factory turbos will push up to 14 to 15 But who wants to keep the factory anything. I am going to get the 935 motorsports twin turbo manifolds and put two gt28's on it when I am done looking for around 650 to 700 but still got other things to get.
1JZGTE swap
JZA70 Front end mod
Old 08-26-2007, 11:18 PM   #6
MDellboy420
MDellboy420's Avatar
MDellboy420 is on a distinguished road
it can but everyone is right..its expensive..im doing it right now to my 90 supra and so far ive spent close to 15,000. To do it right you need the 2JZ, 6-speed tranny, ecu, wiring harness, motor mounts, water pump, and much more..If you dont have some money to spare or arent working full time, dont even think about it
MDellboy420 is offline   Reply With Quote
