Old 08-23-2007, 04:56 AM   #1
oiramm
oiramm is on a distinguished road
Default supra 1991 wont start
hi i am new in this forum and i need your help my car wont start i recharge the battery and replace it but i made i mistake i place the battery on the wrong side and i connect the fire cable on the ground side of the battery and i touch the ground wire in the fire side + of the battery and sparkles came out just for 2 seconds so i change it to the right side so now i have some lights when i open the door the headlights work okay. but no radio no electrical power i try to start the car and nothing not even a sound i checked some fuses and are okay did i messed up an electrical component like the computer or a big electrical part of the car burned ,,,,,thank you for your time please let me know
oiramm is offline   Reply With Quote
Old 08-23-2007, 01:10 PM   #2
west_side_supra
west_side_supra's Avatar
well if your really bad luck, your fuses and relays didnt do there job and just melted like mine tend to do.
other wise i say take a look at the relay box under the hood by the diagnostics box. bet you blew the acc relay.
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 08-24-2007, 05:41 AM   #3
88Tsupra
88Tsupra is on a distinguished road
you know what my friends car was doing that yesterday take into mind though her car was a 4runner..but her negative wire had no ground wire do you have a ground wire and the only way i started her car was to jump start it..make sure there is a ground wire and enough juice
88turbo targa-white
original Pin Stripe
custom intake-Tenzo filter.....Momo racing seats and steering wheel...
apexi exhaust tip-custom 3" piping. Replaced with RSR GT II
NGK plug and wires
HID conversion head lights
HKS Turbo Timer Type-1 (in black)
Tial BOV
BIC DDP
88Tsupra is offline   Reply With Quote
Old 08-25-2007, 02:06 PM   #4
supramacist
supramacist's Avatar
I'm thinking that if you are getting this freaked out over dicking up your battery.
You may not be ready for the challenge that is supra.
I hope you have an ample tool collection.
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
87 Supra 7M-GTE/AT Engine cranks over but doesnt start... Supra-Boy MKIII Supra 7 03-15-2006 11:38 PM
