Old 08-21-2007, 03:02 AM   #1
redmaro
Default Accordion mystery hose?
Where does the small bottom hose connector plug into?
MK3, Auto, Turbo.
Old 08-21-2007, 03:04 AM   #2
dcrusupra
dcrusupra's Avatar
Power steering idle up. A vacuum hose goes from there to a tube in front of the power steering pump.
New Rebuild
My CarDomain
Old 08-21-2007, 03:06 AM   #3
redmaro
What negative effects would this cause if its disconnected? Cause mine has never been conncted.
MK3, Auto, Turbo.
Old 08-21-2007, 03:10 AM   #4
dcrusupra
dcrusupra's Avatar
Your idle will fluctuate, maybe stall, while you turn the wheels while idling
New Rebuild
My CarDomain
Old 08-21-2007, 03:26 PM   #5
mrnickleye
mrnickleye's Avatar
NO. That hose connection on the accordian hose is so the air going into the power steering idle-up valve is 'clean'. If the hose is not hooked up, unfiltered air will be sucked into the accordian hose, AND into the P/S idleup valve (and on into the throttlebody). dirt=bad
MK3 supra Hose Techniques silicon hoses Micahwc Shops & Part Reviews 8 12-09-2012 09:03 PM
Vacuum hose suprabahamut MKIII Supra 10 01-08-2009 12:52 AM
Picture? Power Steering pressure hose ptomko MKIII Supra 4 10-08-2008 02:19 PM
Replacing Clutch reservoir Hose and fixing rock plate (plastic one) Grandavi MKIII Supra 2 09-29-2008 04:49 AM
