Old 08-15-2007, 04:07 AM   #1
Chambers
Chambers's Avatar
Question Small Boost Gauge
Hi all, I'm looking for a small aftermarket boost gauge 1.5 inch dia or smaller, I've looked a lot for one that small but havent been able to find one, if anyone knows of some place that sells a boost gauge that small, that would be real helpfull. Thanks.
Old 08-15-2007, 07:00 AM   #2
Supra2NR
Supra2NR's Avatar
smallest ive seen is at 2 1/16, i believe,
hard to find smaller gauges than that,
hopefully you can find a company that offers them
but, i jus had to say it, i think you wanna go with a reliable company
for the reason thier gauges are reliable, and accurate
ie: autometer, defi, and so on
dont trust good looking gauges if they cant be accurate, you could be getting a wrong reading and there goes your engine
Old 08-15-2007, 11:04 PM   #3
Chambers
Chambers's Avatar
Yea I was looking to fill up the empty space under my head unit with a few guages but the smallest i could find was 2 inch, thanks for the advice anyway, I was wishing HKS had it but they dont. I guess ill figure somthing out. Thanks again!
Old 08-16-2007, 12:01 AM   #4
Supra2NR
Supra2NR's Avatar
well if thats the part youre trying to fill
two units from hks electronics will do
electric boost controller, that doubles as a gauge
and a turbo timer,
Old 08-16-2007, 04:30 PM   #5
Chambers
Chambers's Avatar
Well you see im making my car a NA-T, and im going to try to avoid spending $1000+ on computer stuff when i only plan to run ~6 psi of boost, so I wont need a very complicated set up. thanks anyway for the advice. By the way, I came acrossed a boost guage that seemed smaller than 2inches, it was at pepboy and I think the brand was auto gauge or something similr it was behind glass so i couldnt get a close look but i think i might go with that. Thanks again.
Old 08-17-2007, 11:14 PM   #6
Supra2NR
Supra2NR's Avatar
Its 2 1/6 , I saw those already
Old 08-18-2007, 02:31 AM   #7
Chambers
Chambers's Avatar
Question
Well darn,...... hey what size is the stock boost gauge? Cus the volt meter in my car seems smaller, I havent had time to measure it though, if it is ill just make a custom pod and use that. What you think?
Old 08-18-2007, 05:05 AM   #8
The stock volt meter and boost gauge are the same size... except for the extended box the boost gauge has that bolts onto the back of the gauge cluster. If you're trying to go for a stock look, just swap in the boost gauge and the controller and dump the volt meter.
Old 08-18-2007, 05:30 PM   #9
Chambers
Chambers's Avatar
Well I want to keep the volt meter and just build a pod to go below the head unit for the boost gauge,..... I guesed they were the same size, I was wondering if the stock boost gauge is smaller than 2 inches, but ill get a measurement today. Thanks for the info though!
aftermarket boost gauge hook up? mastergrader007 MKIII Supra 2 05-14-2008 06:08 PM
boost gauge tak2099 MKIII Supra 3 08-21-2007 08:00 AM
Boost Gauge help! frostburn MKIII Supra 27 10-13-2006 08:35 PM
having trouble with my boost gauge! fastsupralife Non-Generation Specific Questions 6 09-12-2006 12:57 AM
