Old 08-10-2007, 08:52 PM   #1
87supran/a
87supran/a is on a distinguished road
Default exactly where is it
i dont know if i already posted this or not, exactly where is the transmission fluid go, or does it use grease. This is my first manual car so i have no idea
87supran/a is offline   Reply With Quote
Old 08-10-2007, 09:10 PM   #2
fulljapan
fulljapan is on a distinguished road
I am not yet a supra owner but i know that:
It goes in the transmission oil pan. Since the tranny isn't automatic there is no dipstick so you can't fill it from the engine bay. But, if you look at the tranny oil pan under the car you will see a drain plug and check/fill plug.
fulljapan is offline   Reply With Quote
Old 08-10-2007, 11:27 PM   #3
j3pz
the proper way of doing it is jacking the car up, crawling under there and theres a huge plug bolt. take it out and using a pump and hose you are supposed to pump the oil in there untill you can stick your finger in there and feel the oil about quarter inch below the plug hole. tsrm says to use 75w-90. i used gear oil for now, after a while im gonna get some royal purple or somthing good like that.
http://www.cygnusx1.net/supra/Librar...aspx?S=MA&P=11
another and easier way to do it, is to take the plug and shifter both out, then pump it in the shifter hole untill the oil starts coming out of the plug hole...
