Old 08-03-2007, 10:03 PM   #1
supraman121
Default What is this?
I found this under the hood it was attach at one end, so i removed it to replace the vacum hose and i was wondering were it attached and how to install it back on the car...
That last image is were it came from in that general place.
Thanks in Advance
Corey Stevens
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 08-03-2007, 10:14 PM   #2
f00g00
Its the dash pot vacuum valve. It goes on the little vacuum hose on the throttle body brown side to the hose. Yours is also missing a little filter that goes on the end of the black tube.
Old 08-03-2007, 10:17 PM   #3
supraman121
What excatly does it do? Do i need it? and is there a replacement for it?
K&N Air Filter
Old 08-03-2007, 10:28 PM   #4
f00g00
Its part of the emission control system. As you decelerate and take your foot off the gas its supposed to hold the throttle partially open for about one second before going to idle to burn the fuel air mixture completely.
Your better off with it hooked up. The little filter just keeps contaminants from entering and gumming up the valve.
Old 08-03-2007, 10:30 PM   #5
supraman121
ok thanks i just cant find the little peg in which to hook up the vacum hose.
K&N Air Filter
Old 08-03-2007, 10:32 PM   #6
f00g00
there is a pic here and it tells you about the dash pot system and how to adjust it on page 8.
http://www.turboninjas.com/mk3supra/...ndiv/06_EC.pdf
