how high can you go?
hello everyone, new to forum, i have a 87 supra that i have been working on for quite a while now, i just recently drove it for the first time and when i hit full boost, i was only at 5-6 lbs. the car has a manual bc, do you think possibly it could be bad? i had it turned up to about 10-15 lbs, i know its not my charge pipes or vacuum leaks so this is the only thing left i can think of. Also i was wondering how high i can boost safely. the car has- hks f-con,fcd, stock pipes and intercooler, hks bov, and straight threw exhaust(hollow cats) and greddy muffler. what psi do you think ill be safe running? any help is appreciated..thanks
10 psi
i wouldnt run any higher than 10 or 11 on the stock turbo
that sounds good to me, i dont want to fry that turbo. i have herd that you can upgrade the stock turbo, has anyone done this? im not sure what the stock trim is but what could you upgrade to?
uh if i remember right it the stock trim to a GT trim they have the trims availible on ebay just look around, search for ct-26 maby
10-15 lbs?
ddnt hit fuel cut? i think u could have fried that turbo already, hopefully it was still in good shape when you turned up the boost my stock turbo gave up on me at 15 psi |
ill search ebay tonight and see what i can find, and i havent had it up past 6 psi yet cause i think i my mbc is bad, it was cut up but still hit stock boost, i think im going to take it out and just shim the wastegate, and as for the fuel cut, i have the hks f-con and fuel cut defender, so i dont think i need to worry about fuel
The most my engine has seen is 10-11 psi. Shortly after I blew the coupler on my 3000 pipe to throttle body. Now it's back at 8 psi. |
thanks for the info, i plan on keeping the fcd on it, but im not going above 10-11 psi, and if i do start blowing charge pipes, ill have to back it down, untill i get the hard pipe kit
i was fine a 12 psi, when my car was stock, til my friggin clutch gave out on me, then i turned the boost down to 10 psi jus get a walbro 255lph fuel pump, and a aeromotive fuel pressure regulator you can still stretch out the injector to compensate for the extra boost and the pump and regulator, you can adjust if needed |
i have 550s and a lexus afm if i get a fuel pressure regulator i know i can safely turn my boost up but what do you need to do about the fuel cut? does anybody know
go to hksusa.com they offer the hks fuel cut defencer,that will solve your problem.. and as far as the the boost, i think 10 lbs is going to do it for now, i checked ebay for some upgraded turbos and found a couple that sounded pretty good, time to start saving up
seams like you got the apropriate mods to support higher boost levels the only thing to do with fuel cut now, is to remove it |
also, does anyone know if i can take the injectors from a 1jz and swap them into a 7mgte or are they different?
I always thought that the 1jz has smaller injectors then the 7mgte
I know that the jdm 2jzgte has the same size injectors as the 7mgte I forgot where I saw this |
ohh ok, i thought they would be bigger in the 1jz being the twin turbo, reason i was asking is cause i have a 1jz laying around (posted on parts for sale)
| All times are GMT. The time now is 05:33 AM. |
