Old 07-25-2007, 11:02 PM   #1
tak2099
tak2099's Avatar
tak2099 is on a distinguished road
Default greddy rs BOV
what would i want to hook the vacuum line to?
tak2099 is offline   Reply With Quote
Old 07-26-2007, 12:23 AM   #2
west_side_supra
west_side_supra's Avatar
you can use the same thing as what the stock bypass valve used.
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 07-26-2007, 01:21 AM   #3
tak2099
tak2099's Avatar
should i T it into the line?
Old 07-26-2007, 06:52 AM   #4
west_side_supra
you can if you want, T it off 1 line into the bypass valve and the other into bov. but the greddy bov will be quiter. and then the engine wont bog down in between shifts.
fidenza cam gears
Old 07-26-2007, 05:51 PM   #5
tak2099
tak2099's Avatar
so would you recomend t'ing or just getting rid of the bypass ?(also where is this bypass valve?)
Old 07-26-2007, 06:20 PM   #6
west_side_supra
its all a matter if you want the car to bog inbetween shifts, or if you want the greddy bov to be louder, its your choice
fidenza cam gears
Speed limiter cut greddy defender old dude MKIII Supra 5 04-08-2007 07:48 PM
