Old 07-25-2007, 09:19 PM   #1
sd88supra
sd88supra is on a distinguished road
Exclamation whats burning?!
Yesterday as I was crusing on the freeway I noticed steam coming out from the gear stick, and I could smell something burning, like oil or something. However, my engine temperature was fine, and my oil pressure was fine too. And it wasn't smoke, it was steam. Now I'm afraid to drive long distances. Any clues?
It's a 5 speed '87 N/A.
-1987 5 spd N/A with TEMS: low miles! All stock with the exception of electric fans and an '89 front bumper, Yokohama 225/50/16 with stock rims. It's a mess and in the garage.
-1987 5 spd Turbo with TEMS: miss-matched tires, needs lots of work, but it runs! Project car.
-1988 N/A auto targa: all stock except 18" rims with Falken 265/35/18 in rear and 225/35/18 in front; daily driver.
sd88supra is offline   Reply With Quote
Old 07-25-2007, 09:30 PM   #2
supramacist
supramacist's Avatar
More than likely you have blown a coolant line.
If you had steam come through your vents...., you may want to inspect the back of your head and block.
Keep us posted. Good Luck.
Old 07-25-2007, 11:15 PM   #3
supradaddy0803
supradaddy0803's Avatar
Check the oil level on your tranny becaue it sounds like your tranny is getting hot. It wont show up on your engine temp because that reads off your thermostat housing.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 07-26-2007, 12:37 AM   #4
supramacist
Any more clues you can give to be more specific would be good for the lot of us.
Old 07-26-2007, 07:01 PM   #5
sd88supra
How do I check the level? I don't know of any diptstick down there. Also, I'd only get the steam coming out of the stick when driving on the freeway.
I opened my hood and found I didn't have an oil cap; I added oil the other day and I guess I forgot to put it back on. I'm sure thats what contributed to the smell. All my coolant lines and hoses seem to be fine.
burning oil why??? ebang MKIII Supra 11 12-06-2010 05:59 AM
burning oil please help cyanide-is-a-way-out MKIII Supra 10 10-31-2007 10:02 PM
Oil burning furia MKIII Supra 9 09-15-2007 04:36 AM
Burning Oil Smell nightreaper Non-Generation Specific Questions 3 09-01-2006 09:34 AM
Burning rich need supra help brad mccarty MKIII Supra 6 02-12-2006 08:49 PM
