Old 07-24-2007, 03:52 PM   #1
fulljapan
fulljapan is on a distinguished road
Exclamation JDM engine
I am about to buy a 87 MKIII with 7m-gte with many features on it ( close to 350hp )
But I have a question: The guy who is selling it said he bought a JDM engine and swapped it himself on the car, and also replaced head gasket on it and put a hks MHG. Is there a way that I can be sure it comes from Japan and that he's not bs'ing me? I'm pretty sure he changed the HG because there was no sign of BHG.
another question... stock tires on a supra are 225/50VR16? Anyone using something else that is cheaper in $$$?
fulljapan is offline   Reply With Quote
Old 07-24-2007, 06:22 PM   #2
gpgtp_22
gpgtp_22 is on a distinguished road
See if it has the egr system (although he could have removed it himself). Ask him to see receipts for the engine. If he bought the jdm engine from somewhere he should have receipts proving it is jdm. I think jdm throttle bodies only have one vacuum port coming off of the top becuase they don't have emissions. The usdm has two. Thats the way it is with my jdm and usdm engine. Other than that I dont know. I hope that helps.
gpgtp_22 is offline   Reply With Quote
Old 07-24-2007, 06:39 PM   #3
88Tsupra
as for you head gasket ask him to see recipes on the parts and machine work..as for the tires its not expensive i bought my khumo escta SPT for 75 each no tax
88turbo targa-white
original Pin Stripe
NGK plug and wires
HID conversion head lights
Tial BOV
BIC DDP
Old 07-24-2007, 11:09 PM   #4
Supra2NR
Supra2NR's Avatar
check the thermostat housing
and i dont know if this one applies but my jdm motor has the oil filter pointing to the side
the usdm motor that i had, had it pointing towards the ground
Old 07-25-2007, 12:42 AM   #5
plaaya69
plaaya69's Avatar
Also ckeck the Throttle body and compair to a usdm one and the t-stat housing neck might have 2 holes compaired to a usdm one with 3(for the bvsv) and like someone else said see if their is a EGR but really the person could have swamped all of this stuff.
Also make sure the motor has low miles like all of the JDM motors... J/K.
Old 07-25-2007, 03:14 AM   #6
Supra2NR
Supra2NR's Avatar
well even if he did take off the egr himself
see how the block-off plate looks like
if it sits perfectly to the manifold it might be a jdm engine
or it could jus be a jdm intake manifold used with the motor
but check the plates anyways, they might give you a clue if its a jdm motor
and the pipe on the heater core
it the driver-side is blocked off and the opening is on the passenger side
its a jdm motor
