Old 07-18-2007, 03:02 AM   #1
suprascoot
suprascoot is on a distinguished road
Default subtle shuttering when accelerating on a brand new engine
I've just finished doing a complete rebuild on my 89T and it is running damn near perfect accept for some subtle shuttering when i'm accelerating. Its most predominant in 2nd and 3rd around 2000 RPM. It almost feels like a inconcistent miss. Idle sounds and feels perfect. Been told it may be my valves not having fully set yet since the head was completely worked during the rebuild. Checked timing again and again. I just have no clue what it could be and kinda frustrated. Any Help Please?????
suprascoot is offline   Reply With Quote
Old 07-19-2007, 06:09 AM   #2
It shouldn't be the valves. If the valves weren't touched when the head was machined, but they were removed and not replaced in the same place and rotation they were in when removed they may be leaking... this isn't something that goes away on it's own. If you had a valve job done they should seat perfectly. Do a compression test if you really think the valves aren't sealing. Did you verify all the valve shim clearances?
As for timing, are you checking the ignition timing or the physical timing of the engine? The timing belt may be off by one tooth on one of the cams or the CPS/distributor drive gear.
Also make sure you're getting a strong spark to each cylinder and make sure all of the engine/ECU/battery grounds are clean and secure.
Old 07-24-2007, 11:27 AM   #3
west_side_supra
west_side_supra's Avatar
id check the spark plugs and also the Coil pack's and harness for melted wires, same thing with the CPS wires
7MGTE - 500hp never dyno'd
fidenza cam gears
