So this supra has a nasty habit of idling out as in when I start it if I don’t have my foot slightly on the gas the rpm's drop until it dies, which is kind of a pain with a standard. The old owner assured me that it was because of the missing muffler and a lack of back pressure. It is a family friend that seems to know enough about cars but I would hate to buy it and a new muffler and find out its something else. Does that sound right or do you think that it could be due to something else?
Run a compression check and pull the codes.
#3 | |
happened to me before check for air leaks and tighten your intake clamps
89 white package twin turbo Quote:
slightly plug the exhaust to simulate backpressure?
1989 supra turbo automatic soon to become a manual K&N, megan dp, gutted cat, 2 1/2" magnaflow cat back NA intake cam, shimmed actuator no A/C or P/S, therefore no ac condensor, compressor and no ps pump or resivior. gutted interior, 4 tweeters, 2 kicker 12"s powered by an MTX 400W 350rms and an audiobahn 400W 300rms |
check your plugs and wire that can be the problem too..that was my problem and yeah check the intake piping as well mines is loose righ now and it does it buh it wont die
88turbo targa-white original Pin Stripe custom intake-Tenzo filter.....Momo racing seats and steering wheel... apexi exhaust tip-custom 3" piping. Replaced with RSR GT II NGK plug and wires HID conversion head lights HKS Turbo Timer Type-1 (in black) Tial BOV BIC DDP |
#6 |
Thanks for the suggestions I will check see what i can do.
#7 |
hmmm, well id agree with everyone above, check the intake pipeing, IC pipeing if its turbo'd. also check all vacume hoses. a lacking muffler wouldnt cause it to drop the rpms hell alot of us are running with no cats and 3 inch pipeing and have no problems at all. if the muffler is plugged i doubt it would cause that kind of problem, if thats the case just chop it off. and put an exhaust tip on it. its not missfireing at all? any codes? <<< you need to put a paper clip or wire or somthing inbetween termainals T and E1 of your diagnostics box in your engine compartment... does it have the stock Bypass valve?
![]() 7MGTE - 500hp never dyno'dexhaust: 3inch pipes no cat/powerhouse manifold/garret gt47 18psi/HKS SS racing wastegate fidenza cam gears intake: PHR 4inch intake/K&N filter/3 inch intercooler/ pipeFMIC/greddy type R bov/ fuel: 550cc PTE/ walbro 255lp / Aeromotive adj pressure regulator transmission: Fidenza flywheel/ACT extreme kit electronics: map ecu 1 / HKS EVC 9 gauges:boost,EGT,oil temp & pressure/aem AFR |
#8 |
The tweezers from your swiss army knife, lol.
I used a 2 inch piece of 18 gauge wire that I used to wire in the Blaster coil. |
#9 |
If it's not going into idle properly check the IDL switch in the TPS and test the ISC.
| engine cuts and dies | uddinf | MKIII Supra | 9 | 09-06-2009 06:56 AM |
| 1986.5 Idling at high RPMS | Sasukevh | MKIII Supra | 2 | 06-14-2007 04:56 AM |
| Start up and engine dies. | Drag0na5h | MKIII Supra | 12 | 01-14-2007 02:04 AM |
| rpms dropping | Supra1989 | MKIII Supra | 0 | 05-01-2006 02:50 AM |
| Sputter @ high rpms with pedal all down! | MKIIISupraTurbo | Non-Generation Specific Questions | 2 | 11-11-2005 01:47 AM |
