Old 07-11-2007, 03:19 AM   #1
suprascoot
suprascoot is on a distinguished road
Default what size aftermarket rims are everybody running
I was just curious as to see what some common aftermarket rim sizes people have on their mkIII supras. Im looking for a set but there are just way too many to make this decision easy. Any feedback would be helpful but the more information you can give me the better (i.e. offsets, rim widths, rim diameters, even pictures if you got them).
suprascoot is offline   Reply With Quote
Old 07-11-2007, 04:31 AM   #2
supramacist
supramacist's Avatar
I'm running the stock 16 inch 5 point mags.
I have heard of guys going up to 18's.
The larger the rim the more top end you'll gain.
But you will also be a bit more slow out of the hole.
Just some food for thought.
Stick with stock. They are good rims. Just stay away from the sawblades.
Old 07-11-2007, 04:43 AM   #3
gomezmk
I run 17x9 on the rear with a 40mm offset. Fronts I run 17x8 with 40mm offset. Rears have 275/40r17 and fronts 245/45R17. No rubbing whats so ever.
Old 07-12-2007, 04:04 PM   #4
pato
pato is on a distinguished road
volk gt-n's
18x8 fronts +38
18x9 rears +42
looks allright . i wanna get 15mm spacers then i recon they would sit perfectly
pato is offline   Reply With Quote
Old 07-13-2007, 02:46 PM   #5
Supra2NR
Supra2NR's Avatar
i got sum black konigs, which i got from a trade lol
17x7 40mm offset
235/40/17 front
245/45/17 rear
Old 07-13-2007, 02:48 PM   #6
west_side_supra
west_side_supra's Avatar
im running on the 18" ADR M-sports. hehe i got them with tires for 300$
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 07-13-2007, 03:29 PM   #7
Supra2NR
Supra2NR's Avatar
paid 75 bucks for mine lol
Old 07-14-2007, 04:21 PM   #8
Jeff_5_7
Jeff_5_7's Avatar
Jeff_5_7 is on a distinguished road
wont the bigger wheels trow off your speedo or can u just get a lower proflile tire the bigger the wheels is the smaller the porfile on the tire ot make the speedo be right
Supras anrt ricers there Japanese Muscle
1988 supra n/a just finsihed 5 speed swap
goal is 400hp with a turbo motor swap
Jeff_5_7 is offline   Reply With Quote
Old 07-14-2007, 05:01 PM   #9
dcrusupra
dcrusupra's Avatar
I went from 15" wheels to 17" wheels on my hyundai and it's only off by like 1 or 2 MPH.
I've test fitted the rims I'm getting and they are 18x8.5 +35mm offset in the front and 18x9.5 +35mm offset in the rear and it fit damn near perfect if not perfect.
New Rebuild
My CarDomain
Old 07-14-2007, 06:52 PM   #10
Syris
Syris is on a distinguished road
I got 18x9 Front and 18x10 Rear with 275/35/18
Syris is offline   Reply With Quote
the weight of rims? rinso Non-Generation Specific Questions 3 03-28-2007 10:38 AM
Rims and Tyres Ice Non-Generation Specific Questions 1 08-07-2006 03:58 PM
Paint Job And Rims Sever_13_ Exterior , Interior, and Detailing 6 07-19-2006 02:25 AM
Question about RIMS! lifesnotfair Off Topic Forum 2 12-09-2005 03:33 PM
