Old 07-02-2007, 02:57 AM   #1
suprascoot
suprascoot is on a distinguished road
Default unsure of aftermarket rim sizes
I've been thinking about buying this really nice set of rims but not sure if they're going to fit. They are 18x8.5 fronts with 20mm offset and 18x9.5 with 25mm offset for the rears. Im not sure if the offset for the fronts will be enough to keep the tires from rubbing so if anybody has some rims arount this size let me know how they run. My suspension and everything is still stock. Also if you think spacers might be an option.
suprascoot is offline   Reply With Quote
Old 07-02-2007, 06:48 AM   #2
oowee623
oowee623's Avatar
what kind and what size of tires do you plan on wrapping them in? and i dont think spacers are needed since supras are pretty wide unless you go for wide body kit
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
Old 07-02-2007, 07:35 AM   #3
88Tsupra
you will most likely be fine with that set up i seen a guy run 17x10 rear and 17x8 or 8.5 not to sure i know its 17 buh he had more then enough clearance for his rims and tires
88turbo targa-white
original Pin Stripe
NGK plug and wires
HID conversion head lights
Tial BOV
BIC DDP
Old 07-03-2007, 03:27 AM   #4
suprascoot
i was thinking 245 for the fronts and whatever will fit for the back... think its really nice having wide back tires... makes rotations impossible though.
Old 07-03-2007, 03:49 AM   #5
dcrusupra
dcrusupra's Avatar
They would fit but they might be sticking out from the fender a little bit. Try to get as close to a +35mm offset as you can get.
New Rebuild
My CarDomain
MKIII - What size stock speakers? redmaro Car Audio and Alarms 33 06-24-2016 11:38 AM
TIRE sizes, whats best size/brand... ghost88 Non-Generation Specific Questions 1 12-08-2008 07:26 PM
IC pipe sizes west_side_supra MKIII Supra 3 04-19-2007 08:03 AM
indentify / for sale Rims (2) vitai0 MKIII Supra 14 08-18-2006 04:24 AM
Measuring Rod, Main bearing sizes Justin727 MKIII Supra 4 12-28-2005 01:43 AM
