Old 06-30-2007, 10:05 PM   #1
carfanatic89
carfanatic89's Avatar
Default Clutches
I have a 87 NA and i have the motor out and replacing it with a used japan one. The clutch thats on the old motor it has a 149,000 miles on it and i dont wanna put it on the new one. Im gonna replace it, I plan to be driving mainly in the city, and some weekend racing. I think that a oem clutch would be ok but, I know nothing about clutches so i have no idea what would be best for me. Can someone give me some opinions on what kind i should get.
Old 07-02-2007, 04:12 AM   #2
Supra2NR
Supra2NR's Avatar
They have to be really really good to make one clutch to last 149000 miles
Even with regular driving
But if ur keeping ur car stock
U can use stock clutches
But getting sumthing like an exedy stage2 clutch will give u a little more durability
Old 07-02-2007, 05:51 AM   #3
What about just upgrading the pressure plate and using a new OEM clutch disk?
Old 07-02-2007, 06:47 AM   #4
oowee623
oowee623's Avatar
i think stock is pretty good, aisin did build a beefy ass transmission, aka the r154 right?
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
Old 07-02-2007, 08:29 AM   #5
supramacist
supramacist's Avatar
If you go oem go toyota oem.
I replaced the clutch in my 91 na before the bhg.
I bought it from o'rielly's. It isn't enough clutch.
Old 10-20-2007, 08:01 AM   #6
carfanatic89
I went stock and i guess i drive to hard for it, it just started slipping and its only been for about 4500 miles but it only slips when the motor is cold.
Supra Engine Powered Dragster
Old 10-20-2007, 10:49 PM   #7
teedoff00
teedoff00's Avatar
teedoff00 is on a distinguished road
If you dont frequently shift at high rpms (i.e. redline) or race, I would stick with stock cuz your daily driving will be much easier, however if you want to spend a little more, an exedy stage two would with a full disk face would be a great upgrade. Feels close to stock but can still handle an occasional street race. This is only true as long as your horsepower at your crank is not too much above stock like 300 max I would say. So whatever you do just dont go cheap and end up having to replace your disk in 10-20K. If you decide stock get the oem aisin clutch, if you go stage two get a exedy or something compareable. If you are planning on more ponies in the future, get a stage three. I run an ACT stage three and it is a bit harsh at times, but streetable with practice, it is a bitch in traffic. Good luck...
teedoff00 is offline   Reply With Quote
Best Performance Clutch SilvaT MKIV FAQ 32 02-22-2007 02:05 PM
auto tranny work mizuboi MKIII Supra 16 01-03-2007 10:46 PM
