Old 06-22-2007, 01:47 AM   #1
finaltable
finaltable is on a distinguished road
Default Exhaust improvement question
I understand that making a more free flowing exhaust will help the performance of my engine (and more important, the 1JZ I would like to put in it eventually.) That said, I do NOT want to have a car that is loud or has one of the obviously aftermarket tailpipes one sees on all the low end Civic/Neons out there; in fact, I want for it to require someone pretty knowledgable about Supra to know that my car is anything but stock.
The other day I was driving next to a Dodge Stealth (the driver was admiring MY car, btw) and noticed that it has two sets of tailpipes where my Mk III only has one. I know that engine is a 6 (though a "V", not and "I") so I wondered if it is possible to double my outbound exhaust channels as well. I realize I am probably stuck with a single exhaust manifold coming off the head but if I could split into two immediately would I realize a similar gain to what I would see with one of the bigger diameter pipes?
Current ride: Not a Supra :-(
finaltable is offline   Reply With Quote
Old 06-22-2007, 02:28 AM   #2
supradaddy0803
supradaddy0803's Avatar
Well my exhaust was rusted out when I got my car so I replaced it and it isnt load at all really but the tip is huge. But HKS is a well known brand and people will have to get close to even see if it is a actual exhaust and not just a muffler and a tip. Now to your next question being a in line 6 and the fact of where the gas tank sits I am sure you would be hard pressed to put duals on your car which is fine a good exhaust will flow just as good as his duals. Stealths kinda suck anyways they reall didnt have a large market of mods out there for them. Also being they are a mitsubishi 3000gt and mitsu engines like the older 4G63 have lots of problems stick with a toyota and he should also. Back to the exhaust a 3" inch exhaust for your N/A engine really doesnt help it much but when you do the 1JZ upgrade it allows you a lot of potential. HKS makes a lot of exhausts for the N/A though like the high power and the sport that look kinda like factory. Turbo and none turbo if it is for the mark 3 they all fit also if your emmisions laws in your state allow it put a test pipe in it more fun that way.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 06-25-2007, 06:06 PM   #3
zuni
zuni's Avatar
zuni is on a distinguished road
Talking
What is a test Pipe:
zuni is offline   Reply With Quote
Old 06-25-2007, 06:33 PM   #4
88Tsupra
88Tsupra is on a distinguished road
you can put a dual tip on ur supra thats what im going to do. I saw a dual top exhaust in a super street mag on a mkiv and now i gotta do it to mines it was just to beautiful. and dont worry it wont be loud as long as u dont gut out your cat keep the cat and u keep the noise down
88turbo targa-white
original Pin Stripe
custom intake-Tenzo filter.....Momo racing seats and steering wheel...
apexi exhaust tip-custom 3" piping. Replaced with RSR GT II
NGK plug and wires
HID conversion head lights
HKS Turbo Timer Type-1 (in black)
Tial BOV
BIC DDP
88Tsupra is offline   Reply With Quote
Old 06-25-2007, 09:31 PM   #5
IHateHacks
IHateHacks's Avatar
A test pipe is a 3" straight pipe with toyota flanges that replaces the main catalytic convertor.
And he is right, having a stock cat will keep the loudness down, along with the nasty'ness.
You have a non-turbo so unless it was a cali car when it was sold brand new, you don't have a pre-cat, which is another big time restriction on turbo cars.
Old 06-25-2007, 10:50 PM   #6
zuni
zuni's Avatar
where is the pre cat located.
Old 06-25-2007, 11:51 PM   #7
Pretty much right after the manifold just before the exhaust piping bends under the fire wall.
Old 06-26-2007, 01:09 AM   #8
zuni
zuni's Avatar
on the down pipe
Question about exhaust RawrXTC MKIII Supra 4 02-09-2009 11:04 PM
Exhaust + Oil Question mkiiisupra MKIII Supra 3 05-24-2008 12:48 AM
exhaust question (not in exhaust faq) sd88supra MKIII Supra 21 11-28-2006 10:52 PM
Exhaust Question Dejvid1785 MKIII Supra 1 07-18-2006 01:27 AM
got an exhaust question supradaddy0803 MKIII Supra 1 06-26-2006 02:11 AM
