Old 06-18-2007, 04:30 PM   #1
ebang
Default Head lights
I noticed that the right headlight is far brighter than the left so I decided to change the left with a new one and onced replaced it is still the same...it is a lot less bright than the right..Is this normal?
1987 N/A Targa 5 speed
no mods as yet
Old 06-18-2007, 06:24 PM   #2
supramacist
supramacist's Avatar
Did you swap it with the right bulb???
Old 06-18-2007, 06:29 PM   #3
ebang
Yeah I did, made sure of that...
no mods as yet
Old 06-18-2007, 09:24 PM   #4
f00g00
I think he is asking if you swapped the left bulb over to the right side and right over to left and see if the brightness goes with the bulb.
Old 06-18-2007, 10:46 PM   #5
also see if you're headlights are aimed correctly. One could be aimed higher or lower than the other. Drive up to a wall of some sort when it's dark out (garage door works well), park about 15 to 20 feet away, and look at where the beam concentrates at for each headlight. If it's about the same distance up from the ground, then they're pretty well aligned.
Old 06-18-2007, 11:36 PM   #6
oowee623
oowee623's Avatar
did you check your fuses it might have blown its near the battery
Old 06-18-2007, 11:44 PM   #7
Alignment is a possibility.
Usually it's wiring.... 20yo OEM 18ga wiring.
I rewired mine to run off the batt/alt and ran all new 10ga wire with new clips for the bulbs and my headlights are bright as day.
Old 06-19-2007, 12:12 AM   #8
supramacist
Ya switch the bulbs around for sure. It could be the bulb is mis-marked.
Allighnment is another good one because that will make 1 look more bright than the other one. I am guessing you have one that is noticeabley brighter than the other.
And just plain old crappy wire. Voltmeter time. Check the amperage running into and out of both sets of wires.
Fuse??? I think both of the lights would be out if a fuse was blown but that's just an opinion.
Did you touch the glass of the bulb during install?? If you did it could be trying to go out prematurely if you are running hallogens.
Old 06-19-2007, 01:12 AM   #9
oowee623
oowee623's Avatar
no, theres a fuse for the left side and a fuse for the right side
Old 06-19-2007, 03:09 AM   #10
ebang
I will do some checking, but to add,.... when I turn on to high beam the one that is really low almost goes off completely.
no mods as yet
Continental Head lights chris lud Shops & Part Reviews 1 02-16-2009 01:17 AM
head lights dont work. 4runninghank Non-Generation Specific Questions 0 12-18-2006 04:00 AM
opening the head lights Tommy88 MKIII Supra 1 06-06-2006 03:06 PM
