i got a code 51 on my car and a friend gave me a non turbo TPS(throttle positioning sensor) and i was wondering if it would work fine for my turbo thank you
88turbo targa-white original Pin Stripe custom intake-Tenzo filter.....Momo racing seats and steering wheel... apexi exhaust tip-custom 3" piping. Replaced with RSR GT II NGK plug and wires HID conversion head lights HKS Turbo Timer Type-1 (in black) Tial BOV BIC DDP |
i would appriciate it alot because im taking off my valves cover today and replacing it so while that was off i was gunna replace the TPS
Yes apparently they are the same part just mounted 180 out from each other.
nice thanx man im gunna try and replace it on monday while i fix my fog lights
seems like everytime i have a day off my car ends up going on jack stands or being taking apart for repairs
im running an NA tps on my turbo, seems to be doing fine.. put it on an Oscope in class and it checked out
1989 supra turbo automatic soon to become a manual K&N, megan dp, gutted cat, 2 1/2" magnaflow cat back NA intake cam, shimmed actuator no A/C or P/S, therefore no ac condensor, compressor and no ps pump or resivior. gutted interior, 4 tweeters, 2 kicker 12"s powered by an MTX 400W 350rms and an audiobahn 400W 300rms |
#6 |
I bought a turbo TPS for my N/A and it didnt work.
How do you get around the 180 degree out issue. Turn the insides of the TPS? It will not mount 180 and still have room for cables. I can not get my car to idle below 2500 RPMs for the life of me.
89 N/A Supra Previous: 90 Turbo 86.5 N/A 85 GT http://s81.photobucket.com/albums/j2...%20For%20Sale/ |
#7 |
hey man i had that idle problem big time today it went up to 3000rpm and it was idling at 1k earlier
so i pulled over and if you check the throttle cable by the throttle body and if you see a nut on it loosing it up and then take a flat head and loosing the bolt...if i had a picture i would show you. but it works fine it went from 3k to 650 and thats the first time my car has ever gotten to 650 rpm then just take the nut and tighten it up mines is a turbo so it works you might have a screw on the side of your thorttle body that you can adjust to lower your rpm
| Need to replace Turbo, Why not upgrade? | gottadiesel | MKIII Supra | 6 | 03-25-2009 10:10 PM |
| HELP PLEASE | Nick0887 | Non-Generation Specific Questions | 4 | 02-28-2009 07:26 AM |
| Dream Offer | Karma_Supra | MKIV Supra | 22 | 10-17-2007 03:04 PM |
| Sequential Turbo Question | suprapoweredsoarer | MKIV Supra | 1 | 06-06-2006 12:13 AM |
