Old 06-09-2007, 04:52 AM   #1
demon2supra
demon2supra is on a distinguished road
Talking ect
anybody no where the ect is located? and is true that it can cause a rich condition?
demon2supra is offline   Reply With Quote
Old 06-10-2007, 01:05 PM   #2
IHateHacks
IHateHacks's Avatar
Yep. I once had an ECT (not on a supra) read -40 degrees all the time when I checked it with an ohmmeter. That would cause a severe rich condition.
Ok go out to your supra and look at the thermostat housing. You see what the thermostat housing is bolted to with those 2 10mm bolts? Thats the water outlet housing. You see those 2 sensors behind the power steering reservoir? The one on top has a green sensor connector and the body of the sensor itself is green, thats your ECT for the EFI.
Its a dealer only part and will run you around $70.
