Old 06-05-2007, 03:31 AM   #1
finaltable
finaltable is on a distinguished road
Default How do I get a key for my '90?
I discovered this evening that the only key I have for my Supra is the valet key which explains why I can't open the hatch with it. How can I get a new one? Does Toyota have key codes for VINs going back that far?
Current ride: Not a Supra :-(
finaltable is offline   Reply With Quote
Old 06-05-2007, 04:34 AM   #2
A good locksmith won't have any problem making a master from a valet key. The valet key just has one extra cut to it.
If you can't find a capable locksmith:
I think for a '90 the dealership may still be able to cut one from the VIN. Otherwise take the passenger door cylinder to a locksmith.
Old 06-05-2007, 05:19 AM   #3
mrnickleye
mrnickleye's Avatar
I just ran into this same problem for a customer's car last month.
The valet key is missing some cut on it.
You can take the car to the locksmith and have a hatch key made without removing the lock.
I did that on my 1990 Plymouth Sundance. He took the key and stuck it into the trunk lock, turned it both ways, pulled it out, and using some VERY powerful magnifying glasses to see, cut it from the tiny marks left on the key.
Old 06-05-2007, 09:14 AM   #4
Most (I'm not saying all, it's been a long time since I've working in that field) older valet keys have an extra cut in the position closest to the tip (some valet keys are a bit shorter than the master). The reason being that it's easier for someone to add a cut to a key then to fill in missing material. Impression cutting is too easy. Typically, when you see a locksmith impressino cutting a duplicate it's because they intentionally undercut the new key to adjust for wear of the old key (this makes for a more solid feeling in the new key).
Regardless, a good locksmith should be able to set you up.
Old 06-06-2007, 11:18 AM   #5
D_Train
D_Train is on a distinguished road
what do original keys look like from an 87 or just an mkIII in general? Is there any way to get "original looking" keys again?
D_Train is offline   Reply With Quote
Old 06-06-2007, 03:23 PM   #6
supramacist
supramacist's Avatar
Man your ride must be cherry if you have nothing better to worry about than keys man.
Old 06-06-2007, 03:31 PM   #7
D_Train
I'm not worried about it, just thought that if it was something cheapish it would be cool to have on the keyring. Take it easy
Old 06-07-2007, 04:04 AM   #8
btwilson86
Super Moderator
btwilson86's Avatar
The key for my 87 looks like these ones, only without the plastic head:
