Old 05-30-2007, 07:57 PM   #1
demon2supra
demon2supra is on a distinguished road
Wink 7mge head same or not from 7mgte
here's a riddle is the 7mge head the same as the 7mgte (with the etc as in valves and cams)
demon2supra is offline   Reply With Quote
Old 05-31-2007, 02:40 AM   #2
Cams and cam/valve covers: no. Head, valves, springs, cam pulleys: yes.
Old 05-31-2007, 03:18 AM   #3
demon2supra
Talking
thanks man cause the machine shop was going to charge 900 bucks for a reman head
Old 05-31-2007, 03:56 AM   #4
I don't follow. Did they want $900 for one but only $300 for the other? Keep in mind that there could be a lot of differences in how the head was rebuilt. One may have only been tanked, had new stem seals installed and springs tested. While the other may have had new springs installed, new seals, been ported and polished, had a valve job and so on.
Ask for some details. There might have been a legit reason for the difference... or they may have been trying to screw you.
Old 05-31-2007, 07:38 AM   #5
demon2supra
no it was that the journals are warped and the mating surface had to milled .35mm and is to much material removed so, the 7mge head if is a match aside from valve covers and the cams i can work that for 135 dollars vs 900 dollars when a 1j swap is about $1500
7mgte head on 7mge block? RCSG_MK MKIII Supra 4 01-01-2008 02:01 PM
