Old 05-21-2007, 04:45 AM   #1
carfanatic89
carfanatic89's Avatar
Default Body Kit
Hey guys im thinking about buying a body kit for my 87 supra and I want to know your opinions
Here's some pic of the body kit, I says that its bolt on and that it easy to install. Do yall think that its really that easy, has anyone ever done a body kit. Do yall think that I can do it, I have never done any body work, I just work on engine and transmissions. Just tell me what you think, if you can will you give me some shortcuts or ways to make it easier,
Thanks
Old 05-21-2007, 05:47 AM   #2
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
Default kit help
hey man. body kits are really strait forward , if it is a good name brand it fits right up otherwise some fiberglassing is needed.. wich is really easy..if you need help ask i'll tell you what i can.
short cuts.... DO not For any resion use wood screws its just stupid ... (the most common method around my area) the correct way to do it is to use the hardware that comes w/ it and maybe some extra brackets you will hafto make..just makes it that much more sturdy...
i cant spell so i just dont try..lol
My 1989 toyota supra mods:83.5 mm bore, ARP main studs, ARP rod bolts,rings, Cometic .060" headgasket, ARP head Studs, Ferra 1 mm oversized valves, port work, Rc 550cc injectors, Walbro 255hp
Turbo: 1.15 A/R T4 twin Scroll turbin - journal .60 A/R compressor, Hallman Pro MBC, Turbo XS Blow-off Valve, 50mm wastegate, hks fcd
Intercooler: 32x12x3 core, 3 inch piping, with clampco t-bolt clamps
Exhaust:Exhaust manifold T4 twin scroll,2JZ 3 inch downpipe Fabed up to fit, Mandrell bent 3in back
Supra_87_mk3 is offline   Reply With Quote
Help me find body parts! sd88supra MKIII Supra 4 10-27-2010 01:51 AM
mk3 supra body differences suprra_girl MKIII FAQ 37 07-17-2009 02:36 AM
Wide body kit question? JPDsupra MKIV Supra 1 04-22-2007 01:10 PM
throttle body 87supraguy MKIII Supra 0 02-17-2006 02:40 AM
Body Kits Guest_Supra00 Exterior , Interior, and Detailing 10 02-14-2005 07:56 AM
