Old 05-17-2007, 04:09 PM   #1
G-string
G-string's Avatar
G-string is on a distinguished road
Default Head bolts
Blowen head gasket, replacing it , what would be some good head bolts to put in and that torque should they be at to hopefully prevent this fromt happe ing again .
to much pizza makes me feal sick
G-string is offline   Reply With Quote
Old 05-17-2007, 04:13 PM   #2
dcrusupra
dcrusupra's Avatar
ARP head STUDS
New Rebuild
My CarDomain
Old 05-17-2007, 04:32 PM   #3
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
thats the only way to go. ARP studs are good up to 100ftp thats what i'll be running on mine or close to it.
My 1989 toyota supra mods:83.5 mm bore, ARP main studs, ARP rod bolts,rings, Cometic .060" headgasket, ARP head Studs, Ferra 1 mm oversized valves, port work, Rc 550cc injectors, Walbro 255hp
Turbo: 1.15 A/R T4 twin Scroll turbin - journal .60 A/R compressor, Hallman Pro MBC, Turbo XS Blow-off Valve, 50mm wastegate, hks fcd
Intercooler: 32x12x3 core, 3 inch piping, with clampco t-bolt clamps
Exhaust:Exhaust manifold T4 twin scroll,2JZ 3 inch downpipe Fabed up to fit, Mandrell bent 3in back
Supra_87_mk3 is offline   Reply With Quote
Old 05-17-2007, 06:36 PM   #4
dcrusupra
dcrusupra's Avatar
Supra_87_mk3 - the edit button is your friend, lol
New Rebuild
My CarDomain
Old 05-17-2007, 06:39 PM   #5
supramacist
supramacist's Avatar
ARP studs. I took mine up to 85 flbs. In 5 settings instead of 3.
Old 05-18-2007, 03:15 AM   #6
G-string
G-string's Avatar
have you found any problems with putting so much torque on the block, the fac specs say liek 55 pounds or 65 pounds some thing like that. since you put the new studs in have you had any head gasket problems
Old 05-18-2007, 04:14 AM   #7
supramacist
g-string....., What up?
Do the studs. Some of these guys actually know what they are talking about and they aren't here to hold your hand.
I went with the studs. I torqued them in five stages. I threw a few 5lb passes in there mixed with 10 lb passes.
I went to 85ftlbs. You are not going to hurt the steel, that is your block.
Make sure you atleast lap your block. Machining the head is a must.
IMO, studs are superior to arp bolts. But that is only an opinion.
Get the tsrm for your car. There is an online tsrm that may be of use to you.
I have the book so I don't know the link but someone does.
Old 05-21-2007, 05:52 AM   #8
G-string
G-string's Avatar
here is a tsrm website.
h:tp://www.cygnusx1.net/Supra/Library/TSRM/MK3/default.aspx
Old 05-21-2007, 05:57 AM   #9
Arp studs and headbolts are the two most popular choices. The problem with the MKIII's head gasket wasn't due to anything wrong with the OEM head bolts or the OEM head gasket... it was the low torque rating. The OEM head gasket can take quite a beating when properly torqued.
I'm running ARP head bolts at 75ft lbs (the OEM head bolts will work fine at this level too, but I'd recommend new ones over reusing the 20 year old ones in your car now).
Old 05-21-2007, 02:56 PM   #10
IHateHacks
IHateHacks's Avatar
Yes, ARP studs are superior to ARP bolts but the difference between any ARP hardware and stock hardware is far greater than any difference between ARP studs and ARP bolts.
The block is iron, not steel, and is about the strongest material you can thread a bolt or stud into. But it does have its limits. In my opinion anyone that goes higher than 80 ft/lbs is crazy and just asking for trouble (in the form of stripped block threads). Titanmotorsports says use 75ft/lbs for high boost applications. I believe Toyota reissued a torque spec of 72ft/lbs for stock head bolts, and thats with using 30wt motor oil for lubricant on the threads like the TSRM says. That is the biggest factor when torqueing head bolts, what kind of lubricant you use. ARP comes with moly lube that is the slickest lubricant you can buy, far superior to motor oil. It says right on the package that 85% of torque applied to any dry, unplated fastener is lost due to friction between the male and female threads. With motor oil the loss is lower and with ARP moly lube its far lower than with motor oil. Just to put it in perspective, for a 12mm stud (7M's are 10mm thread size studs) ARP recommends 86ft/lbs with ARP moly, and with the same stud with 30wt oil you would need to torque that stud to 109ft/lbs to get the same clamping force. Thats a big difference. ARP doesn't list a torque value for 10mm thread sized 190,000psi tensile strength bolts (the bolts I used) so I just went with 70ft/lbs. For 10mm studs, ARP recommends 60ft/lbs with moly and 70ft/lbs for 30 wt oil.
head bolts on jdm engine tone loc MKIII Supra 10 06-03-2007 09:33 PM
head gasket bolts marc MKIII Supra 6 10-23-2006 07:23 PM
Head Bolts, Or Head Studs?? ZauggIt1 MKIII Supra 2 08-08-2006 01:23 PM
ARP head bolts Deputy99 MKIII Supra 2 07-19-2006 11:16 PM
