Old 05-14-2007, 04:32 AM   #1
D_Train
Default New Developments. The plot thickens...
So when i have the thermostat at 70 or above, i hear a waterfall sound behind the dash. at 65 i hear no waterfall sound.
Old 05-14-2007, 08:33 PM   #2
dannydavi
dannydavi's Avatar
i only here my water fall sound at low revs on a cold start, but apparently what you describe with water behind the dash requires you to burp your cooling system. plenty of topics on that at hand.
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 05-14-2007, 08:58 PM   #3
supramacist
supramacist's Avatar
Yep. Burp that puppy.
Old 05-14-2007, 09:20 PM   #4
D_Train
away i burp!
(but i'm loosing coolant too)
Old 05-14-2007, 09:36 PM   #5
dannydavi
dannydavi's Avatar
oh i read that wrong with the no sound at 60 but i would still do that, as for loss of fluid.. is there any visible leaks? how fast do you lose it? any over heating?
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 05-15-2007, 09:34 PM   #6
D_Train
No leaks, no overheating, I lose coolant verrry slowly.
Old 05-15-2007, 09:47 PM   #7
dannydavi
dannydavi's Avatar
hate to jump the gun, but any signs of BHG? that could eat it away slowly...
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 05-15-2007, 10:58 PM   #8
D_Train
I thought about that. No white smoke, no overheating, changed the oil three months ago, nothing wierd about it then. I'll be changing it next week though.
Old 05-16-2007, 01:23 AM   #9
jfunez
jfunez's Avatar
place an empty container on the coolant reservoir drain hose and drive it like usual....after a long drive check to see if there is coolant in the container...If so..then you most likely have a BHG leaking into a water jacket...{like usual}
this causes high presure in the coolant system pushing the coolant out trhough the reservoir and spilling "only" when the vehicle is driven or at high RPM..
Old 05-16-2007, 02:40 AM   #10
supramacist
Could it be as simple as your radiator drain plug is not tightend all the way closed???
