Old 12-06-2010, 03:35 AM   #11
907mge
907mge's Avatar
If the problem is only in the head it will just be the valve seals which aren't expensive but difficult to install. Each seal is hidden under the valve spring. How many miles are on the motor?
Old 12-06-2010, 05:59 AM   #12
agreed on valve stem seals. inexpensive but just as hard as a head gasket fix imo.. at least as time consuming.
i would first check your #3 valve cover gasket. #1&2 valve covers.. 14mm bolts and.. erm am i missing anything up there?
a good test is to see if your pushing an air/ oil mix up through your spark plugs while running.. if your pooling oil in your plug galley and see small air bubbles coming up through the sealing part of your spark plug wires.. then yes defiantly valve stem seals
just my 2 cents worth
burning oil please help cyanide-is-a-way-out MKIII Supra 10 10-31-2007 10:02 PM
Oil burning furia MKIII Supra 9 09-15-2007 04:36 AM
whats burning?! sd88supra MKIII Supra 4 07-26-2007 07:01 PM
Burning Oil Smell nightreaper Non-Generation Specific Questions 3 09-01-2006 09:34 AM
Burning rich need supra help brad mccarty MKIII Supra 6 02-12-2006 08:49 PM
