Old 05-13-2007, 02:20 PM   #1
ebang
Default burning oil why???
Ok...I got this car since February I did tune up oil change all that stuff..This Saturday was the first time I took it for a long drive...total 250kms. I decided to check the oil today and it was all gone!...What happened??. There is no visable oil leak to speak of that I can see or it would be all over my driveway. Anyone know why it would be burning that much oil?...How serious is this?...
1987 N/A Targa 5 speed
no mods as yet
Old 05-13-2007, 02:25 PM   #2
dcrusupra
dcrusupra's Avatar
Well, if you are burning oil its probably that your piston rings are worn and the oil is getting into the cylinders on top of the pistons where the combustion takes place and gets burned off when the spark plugs ignite the air/fuel mixture.
New Rebuild
My CarDomain
Old 05-13-2007, 04:57 PM   #3
ebang
one other thing whenever I start it up in the mornings there is a hugh puff of blue smoke from the exhaust.
no mods as yet
Old 05-14-2007, 04:17 AM   #4
Kuban
that sounds more like valve guides. anyone else agree?
-868 Miles on new jasper engine
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-apexi ride high 7 way adjustables
-eibach springs
-slotted rotors
-mkIV TT rims (front)245/45/17 (rear)285/40/17
-targa
-greddy turbo timer
-egr eliminated
-3" turbo back, no cat, no resonator, Apexi N1 back.
-n/a cams
Theres others ill think of later.
Old 05-14-2007, 05:10 AM   #5
redmaro
Agree, but to consume that much oil he probably also has a tired engine.
MK3, Auto, Turbo.
Old 05-14-2007, 12:10 PM   #6
ebang
ok...what do you mean by valve guides and how do I go about fixing it or testing that it is that?
no mods as yet
Old 05-14-2007, 12:22 PM   #7
supradaddy0803
supradaddy0803's Avatar
I would suggest doing a compression test first off to eliminate the piston rings. Vavle guides suck just because the easiest way to do them is to remove the head and then do them because you have to remove the valve springs. My old 7m was doing the same thing if it sat a while when I was out of town it would throw smoke for like 10 seconds. But on a lighter note valve guides are cheap to buy but that doesnt make them easy to get to. Most people when you get ready to do those you are already there might was well rebuild the whole head. That is what they were saying about a tired 7m it may just be ready for a rebuild.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 12-05-2010, 09:51 PM   #8
Termen
Termen is on a distinguished road
Default oil burning
Sorry to bring this question back up but i have the same original problem. the oil just disappears within three weeks. and its not throwing blue smoke. oil pressure seems fine and im not loosing any significant power. any ideas.
Termen is offline   Reply With Quote
Old 12-05-2010, 11:57 PM   #9
Sonyps307
On eBay u can buy a completely rebuild head with new parts for the 7m for 400$ then you swap them out and send it back if you want
Old 12-06-2010, 02:42 AM   #10
Termen
is that the problem, the hole head????
burning oil please help cyanide-is-a-way-out MKIII Supra 10 10-31-2007 10:02 PM
Oil burning furia MKIII Supra 9 09-15-2007 04:36 AM
whats burning?! sd88supra MKIII Supra 4 07-26-2007 07:01 PM
Burning Oil Smell nightreaper Non-Generation Specific Questions 3 09-01-2006 09:34 AM
Burning rich need supra help brad mccarty MKIII Supra 6 02-12-2006 08:49 PM
