Old 05-13-2007, 05:25 PM   #11
j3pz
Originally Posted by cars4me89
well hopefully you havent changed the fluid yet because if you said that the transmission fluid has never been changed it would be horrible for the tranny to put new fluid in if it is extremely old, the best thing to do if it is that old would be to have the trans live out its life with the same fluid in it.. do not change it
not disagreeing with you but with a post like that you may want to explain why so people will understand it better... im also curious as to why you wouldnt want to do change it
Old 05-13-2007, 06:29 PM   #12
Bill UK
AEM EMS
Bill UK's Avatar
More info here.
http://www.cygnusx1.net/Supra/TechTips/transmission_filter.aspx
Old 05-13-2007, 08:55 PM   #13
cars4me89
cars4me89's Avatar
cars4me89 is on a distinguished road
well the reason its a bad idea to change old fluid if its never been changed is because the fluid gets all the dirt and junk built up and the hoses and lines expand and since automatic transmissions run by fluid pressure, the old fluid expands with the gunk build up and expands the hoses. So what happens when you replace that old gunked up expanded fluid with fresh new fluid? the transmission can build up the proper pressure to function. This is a very vague and general explanation and is probably partially incorrect, anyone else who knows more please expand on this.
1987 Toyota Supra 7M-GE Natrually Aspirated Automatic
http://www.cardomain.com/ride/2385905
Currently enrolled in UTI (Universal Technical Institute.. ya ya say what you want bout the school lol its got some nice benefits though), have about two years of auto experience so far.. only 18 years old. My supra's older than me :P
-Phil
cars4me89 is offline   Reply With Quote
Old 05-13-2007, 09:16 PM   #14
supramacist
supramacist's Avatar
All I can say Is I have always been told that if you haven't ever changed it...., Don't. Pretty much for the same reason as stated above.
Old 05-14-2007, 07:19 PM   #15
Somajunkie
Somajunkie is on a distinguished road
Default Halp!
Hello I know this isn't in direct correlation with OP problem, but I have a prolem w/ my Transmission fluid leaking. I am a noob and just recently purchased the Supra. According to the guy who sold it to me his mechanic overfilled the Tranny with 2.5qts when in fact it should be 1.7. He told me to replace the fluid, drain the old and replace w/new. Every time I use it it creates two little puddles, the more i use the car the bigger the puddles. The leak seems to be coming from somewhere by the tranny pan but I'm not too sure. The puddles are not extremely dense and at most are the span of my extended hand, but they still worry me. So if you guys could be of some help i would greatly appreciate it!
Somajunkie is offline   Reply With Quote
Old 05-14-2007, 07:25 PM   #16
redmaro
Check the tranny oil pan gasket.
MK3, Auto, Turbo.
Old 05-14-2007, 11:55 PM   #17
Somajunkie
i checked the pan basket but there doesnt seem to be a problem there, but whatever is right behind (please excuse my lack of an adequate technical term) it seems to be the source of the leak since i can see some tranny fluid build up there. So I dunno
Old 05-15-2007, 05:25 AM   #18
cars4me89
cars4me89's Avatar
you said that the leak looks like its coming from whatevers behind it.. with leaks its sometimes hard to pinpoint exactly where its coming from. You should purchase a couple cans of brake cleaner and clean the entire underside of the transmission very well.. drive it for a couple days then take another look and try to identify where its coming from and if it is coming from the back of the transmission, that's where the transmission connects to the driveshaft and it could be leaking from the seal.
-Phil
Old 05-16-2007, 02:57 AM   #19
Somajunkie
Edit:
Any estimate on how much that would cost to repair? Supposing it was leaking from the seal?
Old 05-17-2007, 12:51 AM   #20
RNEMESiS42
RNEMESiS42's Avatar
RNEMESiS42 is on a distinguished road
Well, I don't know if the previous owner ever changed it, but I assumed he did since it was a nicely maintained car. I can tell he did, or tried, because I went down there and the bolt was all rounded off...so I didn't even try to get it off.
The reason I wasnted to change the tranny fluid in the first place was because whenever my car hasn't been driven for a while before going onto the highway, you have to push hard on the gas to make it shift into the next gear. The whole car "whumps." It didn't used to do this, until it sat for a year in a garage. So...I shouldn't change it? Just adding new fluid is good enough? If I'm still going to change it, I wanted to replace the drain plug, too...but I don't know where to get one that fits. This is the closest thing I could find, but it doesn't mention what size it is at all.
White 1987 N/A. Automatic. Targa top. TEMS
RNEMESiS42 is offline   Reply With Quote
Transmission fluid check cgreiner MKIII Supra 1 09-22-2008 02:09 AM
Transmission Fluid capacity suprabahamut Non-Generation Specific Questions 2 09-18-2008 04:30 AM
Transmission Fluid Change shiftysupra MKIII Supra 2 09-16-2008 11:21 AM
transmission fluid suprabahamut MKIII Supra 2 08-12-2007 06:04 PM
Transmission Fluid Change phillip_o_hj Non-Generation Specific Questions 7 02-09-2007 08:56 PM
