Old 05-09-2007, 05:02 PM   #1
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
Default To add to the Fuel Cut topic w/o stealing thread
i have the HKS FCD...my engine is bored .50 over,NGK plugs and wires, i only have a stock turbo and a MLS HG,ARP Studs, hallman MBC,Turbo XS BOV, and a make-shift intake (cone filter) im only going to run 10 psi until i do fuel pump and such. i was going to put the FCD on but do i even need it for this stage of upgrades. as of now stock fuel system but my next move is Walbro and 550's... also would really like to get my hands on a lexus AFM...
does anyone know what a car with this upgrade level should run?
My 1989 toyota supra mods:83.5 mm bore, ARP main studs, ARP rod bolts,rings, Cometic .060" headgasket, ARP head Studs, Ferra 1 mm oversized valves, port work, Rc 550cc injectors, Walbro 255hp
Turbo: 1.15 A/R T4 twin Scroll turbin - journal .60 A/R compressor, Hallman Pro MBC, Turbo XS Blow-off Valve, 50mm wastegate, hks fcd
Intercooler: 32x12x3 core, 3 inch piping, with clampco t-bolt clamps
Exhaust:Exhaust manifold T4 twin scroll,2JZ 3 inch downpipe Fabed up to fit, Mandrell bent 3in back
Supra_87_mk3 is offline   Reply With Quote
Old 05-09-2007, 05:04 PM   #2
Supra_87_mk3
my prob is i don't know if i will be hitting fuel cut b/c i took the top end off to do the HG swap (damn 7m's) and i cant get the frickin turbo off... but i have been informed i will hit F/C when its done.... (i do have a spare turbo w/ semi low mile's...)
Old 05-09-2007, 05:55 PM   #3
IHateHacks
IHateHacks's Avatar
Uhhh what do you mean you can't get the turbo off? So you are saying you left the exhaust manifold and turbo still bolted to the head when you did the head gasket? Then how did the machine shop plane the head with it still attached?
You should not hit fuel cut at 10psi.
Old 05-10-2007, 06:48 PM   #4
Supra_87_mk3
no im saying i cant get the turbo and man. off to get the head done.
Old 05-14-2007, 04:13 PM   #5
Supra_87_mk3
just to updat i cut off the exhaust right after the res. and now the turbo is loose (the bolts were stripped) so my project sjould be almost done.
Old 05-21-2007, 05:54 AM   #6
Supra_87_mk3
the head is off and on its way to be decked.if you didn't understand my first post, everything was off but the turbo therfore i couldnt actualy pull the head to do the gasket, bolts were stripped but i did get it off. thanks for your help.
fuel pressure boost32 Non-Generation Specific Questions 1 08-10-2008 10:19 PM
How much Boost on Stock Internals? abhattan MKIII Supra 26 02-20-2007 06:30 PM
