Old 05-15-2007, 08:36 PM   #11
cars4me89
cars4me89's Avatar
cars4me89 is on a distinguished road
I've got 225/50/16 in front and 245/50/16 in the back.. i get comments all the time on how they look "beefy" i think they fit well
1987 Toyota Supra 7M-GE Natrually Aspirated Automatic
http://www.cardomain.com/ride/2385905
Currently enrolled in UTI (Universal Technical Institute.. ya ya say what you want bout the school lol its got some nice benefits though), have about two years of auto experience so far.. only 18 years old. My supra's older than me :P
-Phil
cars4me89 is offline   Reply With Quote
Old 05-16-2007, 01:58 PM   #12
redmaro
You got teh 245/50/16 in the back with the stock rims?
PICS?
MK3, Auto, Turbo.
Old 05-16-2007, 07:05 PM   #13
Sonic
Sonic's Avatar
Sonic is on a distinguished road
Default the answer
Originally Posted by ebang
I could not find the answer in search, but will P215/55/R16 fit on stock rims for my 87?
the flange is the most important part on your rim for example "5j" that is what determines how wide you can go on your tire . the flange is what takes the most punishment on your sidewall .
I do a lot of testing and development for good year , and would like to help if i can ...well try at least lol .
Sonic is offline   Reply With Quote
Old 05-18-2007, 04:38 AM   #14
supraman121
well 225/50/r16 225 (the higher the number the wider the tire) is the width 50 (the lower the number the lower the profile) is the hight and r16 is the rim size i went to tire rack and looked it up, just went for replacment wheels and the repair manual might tell you..
So mine lookes like it should your probly looks more like the tires on my dad tacoma he has 215/55/r14 or somthing like that taller and skinnyer
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 05-18-2007, 10:51 AM   #15
Sonic
Sonic's Avatar
Originally Posted by supraman121
well 225/50/r16 225 (the higher the number the wider the tire) is the width 50 (the lower the number the lower the profile) is the height and r16 is the rim size i went to tire rack and looked it up, just went for replacement wheels and the repair manual might tell you..
So mine looks like it should your probably looks more like the tires on my dad tacoma he has 215/55/r14 or something like that taller and skinnyer
ok 225/50 R16
225 is your width yes , its 225 mm wide 50 is your sidewall height (50 % of 225 mm) R stands for radial construction and 16 is your rim diameter .
then there's a lot of smaller letter explaining your load index rating speed and construction date ext ext.
Old 05-19-2007, 04:06 AM   #16
supraman121
well you said "Funny?...wouldn't it just make the car seem to sit higher off the ground?"
My answer was no cause my tire's are a lower profile then yours are. Cause of the 50. I guess i should have said that from the start sry.
K&N Air Filter
Old 05-27-2007, 01:44 AM   #17
Hey guys, the stock size is actually a 205/55/16. You can also run a 215/55/16 (a teeny bit taller) and the most popular, 225/50/16. The last size gives you the most useable tread on the ground, and is back to the stock sidewall height. I work as a tire tech at America's Tire Co., and can look up any other tire info you guys need.
And tire size (X/Y/RZ) works like this:
X= Bead to bead length in millimeters
Y= The percentage of X left over for sidewall height
R= Radial Tire construction
Z= Rim size, in inches (16 inches for stock wheels)
Tire pressure? dannydavi Non-Generation Specific Questions 11 08-16-2007 06:03 AM
Tire Question mrnickleye Non-Generation Specific Questions 5 10-29-2005 07:29 AM
