Old 05-03-2007, 10:54 PM   #1
joebuffalo
joebuffalo is on a distinguished road
Default Check Engine Light
I just did a complete engine rebuild (HG issue...replaced finally with metal!)
We put the motor back in the car and tried to start. It turns over but won't crank. With the battery connected and the key NOT even in the ignition....the check engine light is on!! Any ideas????????
joebuffalo is offline   Reply With Quote
Old 05-03-2007, 11:04 PM   #2
supramacist
supramacist's Avatar
It has to crank to turn over. It won't turn over if it doesn't crank. Ya folla?
Need more input. Some pics would be nice even if they are from your phone.
Help us help you.
Old 05-04-2007, 01:33 AM   #3
redmaro
Do a diagnostic, look for the post in the FAQ's section.
MK3, Auto, Turbo.
Old 05-04-2007, 02:03 AM   #4
joebuffalo
It cranks/turns over but will not start......we have fuel, air but no spark. We thought it was the igniter(ohm it all out as per TSRM and all signs pointed to it) changed it and still have no spark. I have read and searched all over the forums and can't find anybody who has had the CEL on without the key even in the ignition!! We will do a diagnostic and let you guys know....thanks!!!
Old 05-08-2007, 03:01 PM   #5
lexushead
lexushead is on a distinguished road
Default No start
Check all your grounds..You have one that is not connected or a bad one..Gaurenteed...
lexushead is offline   Reply With Quote
Check Engine Light & Warning light on Chomper MKIV FAQ 19 02-11-2011 12:51 PM
check engine light suprakid91 MKIII Supra 0 10-19-2007 07:33 PM
Check Engine Light Johnny boy 82 MKIII Supra 2 06-09-2006 09:41 PM
check engine light ironcobra2002 MKIII Supra 4 11-05-2005 04:07 AM
