Old 04-25-2007, 01:34 AM   #1
cars4me89
cars4me89's Avatar
cars4me89 is on a distinguished road
Default Gas cap door spring
I was wondering if anyone could post a picture of their gas cap door because mine wont spring open when I pull the release.. obviously some kind of issue with the absence of a spring in the gas cap door. please and thank you
1987 Toyota Supra 7M-GE Natrually Aspirated Automatic
http://www.cardomain.com/ride/2385905
Currently enrolled in UTI (Universal Technical Institute.. ya ya say what you want bout the school lol its got some nice benefits though), have about two years of auto experience so far.. only 18 years old. My supra's older than me :P
-Phil
cars4me89 is offline   Reply With Quote
Old 04-25-2007, 02:01 AM   #2
j3pz
haha. oh sorry your serious. i actually have the same problem. i usually just wedge something under the release lever and then run around to the door and open it, start pumping gas, then remove the object. im content with it, but some other may not
Old 04-25-2007, 05:01 AM   #3
The spring steel thingy will break eventually. On my Camry, I got one of those little springs that came with the electric fan mount that you use to mount it to the radiator.
You can probably find something at Lowe's or Home depot.
I used a 'self-tapping' screw, and mounted it inside the door area to the body. Never goona have a problem again.
Old 04-25-2007, 01:39 PM   #4
j3pz
im gonna try that ^^
Old 04-25-2007, 03:04 PM   #5
supra_91
supra_91's Avatar
i have the same problem only it does it when its really cold outside
Old 04-25-2007, 03:11 PM   #6
Before the spring, I tried using some firm foam rubber, but because the door is closed 99% of the time, it took a 'set', and lost its springy-ness.
Old 04-25-2007, 04:29 PM   #7
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
Talking
mine also did that i finally cut it and velcroed so it doesn't hang open.
My 1989 toyota supra mods:83.5 mm bore, ARP main studs, ARP rod bolts,rings, Cometic .060" headgasket, ARP head Studs, Ferra 1 mm oversized valves, port work, Rc 550cc injectors, Walbro 255hp
Turbo: 1.15 A/R T4 twin Scroll turbin - journal .60 A/R compressor, Hallman Pro MBC, Turbo XS Blow-off Valve, 50mm wastegate, hks fcd
Intercooler: 32x12x3 core, 3 inch piping, with clampco t-bolt clamps
Exhaust:Exhaust manifold T4 twin scroll,2JZ 3 inch downpipe Fabed up to fit, Mandrell bent 3in back
Supra_87_mk3 is offline   Reply With Quote
Old 04-25-2007, 07:57 PM   #8
tone loc
tone loc's Avatar
i also had the same problem all i did was put a nickle between the black spring and the part it puts presure on and it works perfect.
Old 04-25-2007, 10:48 PM   #9
dannydavi
dannydavi's Avatar
I Got bored and created this in Paint for you, i know you didnt need the explanation of what each item was, and also didnt need the other two pics... but like i said, i was bored.
WOW! that came out awfuly blurry.
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 04-26-2007, 02:02 AM   #10
j3pz
lol i give you a B for blurry
