Old 04-24-2007, 07:27 AM   #1
wahid001
wahid001 is on a distinguished road
Default need help replacing u-joints
i just bought a car from another province and in order to pass the inspection i would need to replace the u-joints and if someone could help me with this then i would really appreciate it thanx in advance
1987 supra
turbo
3.0 v6
wahid001 is offline   Reply With Quote
Old 04-24-2007, 03:31 PM   #2
Mine started making a click and squeek. I removed the driveline and dropped it off at the local driveline repair shop.
They replaced all the joints, and the center support bearing, then balanced it. $300 retail. Perhaps cheaper where you live.
Now I have lube fittings on the joints, so once a year I can give it a squirt or 2.
Old 04-24-2007, 04:18 PM   #3
supramacist
supramacist's Avatar
I wouldn't suggest you change your own u joints if you have never done it.
I have done a few and they are always tricky. If you don't know the tricks. You could mess something up severely.
SO I agree, pull the shaft and take it to a drive line shop. Or take the car and let them pull it. I also preferr spicer u joints but I don't know if you can get them for a supra. Good luck man.
grease zerks are always a plus. Lube them up untill the seals pop with the grease. Your good.
Replacing the headgasket burton51m Show n Tell 4 07-12-2010 04:47 AM
Replacing my vavle cover gasket mkiiisupra MKIII Supra 0 11-18-2008 06:50 PM
replacing knock sensors and rewiring rocktownsupra21 Non-Generation Specific Questions 2 06-09-2008 01:25 AM
Tie Rod End and Ball Joints!! KrnSupra2307 MKIII Supra 6 02-27-2007 11:01 PM
