Old 04-24-2007, 09:35 PM   #11
dannydavi
dannydavi's Avatar
Originally Posted by cars4me89
same problem you did with the misfire, turned out to be the 6th cylinder plug wire was closing onto the plug all the way. To fix it, I just took some long needle nose and clamped the inside together
was or was not closing onto the plug all the way? if you clamped them together to resolve the issue, i'll assume you meant was not closing onto plug all the way, and in that case i will def check that as well when i install my NGK wires. Make sure they grasp the plug nice and snug.
As for the RTV gasket goo, do you guys put that on the uppper intake to throttle body?
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 04-24-2007, 10:32 PM   #12
supramacist
supramacist's Avatar
New wires shouldn't have to be tweeked, by anything more than your hand.
Old 04-24-2007, 10:47 PM   #13
dannydavi
dannydavi's Avatar
oh yeah they shouldnt... but you heard dudes post up there, he had to tweek his... so it couldnt hurt to check.
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 04-25-2007, 12:33 AM   #14
cars4me89
cars4me89's Avatar
cars4me89 is on a distinguished road
ya new wires aren't supposed to have to be tweaked.. thats what I thought and I got the misfire.. for this reason is why I dont like the MSD. yes, it was that the clamps inside the boot weren't fully clamped onto the plug.
1987 Toyota Supra 7M-GE Natrually Aspirated Automatic
http://www.cardomain.com/ride/2385905
Currently enrolled in UTI (Universal Technical Institute.. ya ya say what you want bout the school lol its got some nice benefits though), have about two years of auto experience so far.. only 18 years old. My supra's older than me :P
-Phil
cars4me89 is offline   Reply With Quote
Old 04-25-2007, 12:34 AM   #15
cars4me89
cars4me89's Avatar
RTV... I didn't put any RTV on my throttle body to intake manifold.. I simply purchased a new gasket from Toyota and installed that. It works fine.
-Phil
Old 04-25-2007, 01:03 AM   #16
dannydavi
dannydavi's Avatar
thanks alot man. Is there some sort of "rule of thumb" for putting RTV where gaskets go, or is it just something you gotta look up in a manual? cause when i took it off it looks like there was some sort of gasket sealer used is why i thought of buying some and using some, but now since i have to take it off again... i'll make sure to go straight gasket... sucks you have to buy those things in a whole set..
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 04-25-2007, 01:21 AM   #17
cars4me89
cars4me89's Avatar
Default a whole set?
I just the two throttle body gaskets for each side from Toyota.. like $15. and just use a scraper or flat-head screwdriver to scrape off whatever old gasket might be on there.. also while the throttle body is off, clean off the throttle body plate using some brake cleaner.
-Phil
Old 04-25-2007, 06:57 AM   #18
dannydavi
dannydavi's Avatar
i did do the cleaning cause it looked yucky in there, as for the gaskets, i guess i was looking in the wrong spot... well not really, cause i get the entire(upper and lower) intake gasket set for 10.97 at kragen or napa.
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 04-27-2007, 04:35 AM   #19
dannydavi
dannydavi's Avatar
Ok so i fixed the problem, i took out all the plugs to check gap and what not, and two of the plugs were broken on the insulator part, once i cleaned out the holes really good, got new plugs, put it all together... it ran really smooth. Me Happy ... so it probably wasnt the wires... but at least i got new wires now..
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 04-27-2007, 04:49 AM   #20
Monkey
Monkey is on a distinguished road
The proper tool name is a feeler gauge and for spark plugs, it's not crucial to gap them (just make sure they have a gap lol). Unless they are for race application then measurements are necessary. And for spark plug wires, I bought a set of the MSD wires and had the exact same problem you did with the misfire, turned out to be the 6th cylinder plug wire was closing onto the plug all the way. To fix it, I just took some long needle nose and clamped the inside together, by the way I HATE MY MSD WIRES. I'm switchin to factory as soon as I get the time. Don't waste your time with aftermarket, stick with Toyota, at least in my opinion, hell if you want the MSD wires you can have em from my car for free.. haha.
Wow, i can tell you're not a mechanic. Yes, genius, it IS crucial to gap plugs. Why do you think the gap specs for every car known to man has the spark gap specs under the hood? It's there for a reason.
Monkey is offline   Reply With Quote
Transmission filler plug elsleepster Non-Generation Specific Questions 3 11-02-2008 04:44 PM
plug locations for injectors kidthunder650 MKIII Supra 1 06-05-2007 04:36 AM
Plug or hose came off back of block f00g00 MKIII Supra 3 05-20-2006 11:01 PM
new mk3 owner, spark plug galley full of oil!???? katillidie MKIII Supra 6 03-24-2006 05:09 AM
R154 drain plug? Suprapowaz! MKIII Supra 2 03-17-2006 06:16 AM
