Old 05-09-2005, 05:58 AM   #1
87supraguy
87supraguy is on a distinguished road
i have an 87 supra with an aftermarket sunroof. problem im having is it wont close. when i open it the motor keeps going but when i try to close it nothing happens.. please help its hot out and i want to get it to work asap
87supraguy is offline   Reply With Quote
Old 05-09-2005, 02:43 PM   #2
KingDiamond
if you can access them check the bolts on the sides near the back of the sunroof, mine came with aftermarket also, and i found one bolt was missing, and the other was loose. I still need to adjust it, but it works now. If you can't access the bolts with the roof closed, try to push the button to the open position, and very gently push up on the roof, this might help open it, and then hopefully you will be able to solve your problem.
Old 05-10-2005, 09:02 PM   #3
87supraguy
what bolts are u talking about??? does the roof have to be open to check them? arenthey in the track of the roof???
Old 05-10-2005, 09:53 PM   #4
KingDiamond
yes they are near the back, they are not actually in the sunroof glass itself, and the easiest way i know to access them is with it open.
Windows & Sunroof will not move XcyborgX MKII Supra 3 12-31-2008 07:34 PM
Leaky Sunroof scruffboy Non-Generation Specific Questions 0 11-22-2005 12:34 PM
