Old 04-12-2007, 01:03 PM   #1
curtismoff
curtismoff is on a distinguished road
Default Where's the power
I just did a JDM swap non turbo.Everything is hooked up.The motor idles and runs good.The check engine light is not on.I think it should have way more power than it has.It really doesn't start pulling good till 5,000 rpm's.Once it's there it's like a powerband kicks in WTF should the rpm's be that high before you feel the power? Anyone have a suggestion.
curtismoff is offline   Reply With Quote
Old 04-12-2007, 02:18 PM   #2
IHateHacks
IHateHacks's Avatar
What is the base ignition timing set to?
Old 04-12-2007, 02:29 PM   #3
curtismoff
That was my first thought.I checked it and it was @ 10 but the dist. is at a limit.I can't move it any more advance I would like to see how it runs @ 12-15 but the lockdown won't allow it.
Old 04-12-2007, 02:46 PM   #4
IHateHacks
IHateHacks's Avatar
Are you disabling the electronic advance when you are checking the ignition timing? Is the engine at full operating temperature when you are checking the ignition timing?
Sounds like you installed the distributor a 1 or 2 teeth off.
Greetings! importauto Import Auto Center 7 06-21-2009 07:42 AM
getaway in stockholm... (i think thats how you spell it) kelogg Road Racing & Autocross 3 06-03-2008 10:53 PM
Lsd RussianMK3 Drifting 6 12-10-2006 05:42 PM
Ghetto is a good seller ARZ Buyer/Seller ratings 0 11-15-2006 11:58 PM
MEET UP's TEAM_Bastos Drifting 0 03-02-2006 09:09 PM
