Old 04-10-2007, 06:29 AM   #1
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
Default Help..head gasket
ok so i know first hand on how common the BHG is on my mk3 due to the fact i've owned 3 and all of wich had them....my trouble is, the newest supra added to my collection is a 89 7mgte bored .50 over and i'm having trouble finding a gasket kit for it...
My 1989 toyota supra mods:83.5 mm bore, ARP main studs, ARP rod bolts,rings, Cometic .060" headgasket, ARP head Studs, Ferra 1 mm oversized valves, port work, Rc 550cc injectors, Walbro 255hp
Turbo: 1.15 A/R T4 twin Scroll turbin - journal .60 A/R compressor, Hallman Pro MBC, Turbo XS Blow-off Valve, 50mm wastegate, hks fcd
Intercooler: 32x12x3 core, 3 inch piping, with clampco t-bolt clamps
Exhaust:Exhaust manifold T4 twin scroll,2JZ 3 inch downpipe Fabed up to fit, Mandrell bent 3in back
Supra_87_mk3 is offline   Reply With Quote
Old 04-10-2007, 07:23 AM   #2
supramacist
supramacist's Avatar
Have you tried horsepowerfreaks.com ???
Get Dave at ext 103. He knows his stuff man and get's your parts to you in days.
Old 04-10-2007, 04:35 PM   #3
Supra_87_mk3
thank you i'll try tonight after work.
Old 04-12-2007, 05:01 PM   #4
Supra_87_mk3
Exclamation
ok so i'm a member on HPF.com now but i still cant find a oversized head gasket..i didn't call yet but is there anywhere else i can look?
Old 04-12-2007, 05:05 PM   #5
supramacist
If hpf can't get one you may try there brother company.., titan motor sports.
I'll be surprised if dave can't find you one.
You may have to go with less of a head gasket so you can trim it with a razor. But that won't do you any good. Call them man. Hell I'll call him real quick.
Old 04-12-2007, 05:11 PM   #6
supramacist
Alright he must be busy. Call them and keep calling until he picks up. This guy has gone out of his way for me on some of the parts I have ordered. That forum over there is really slow. I think there are only a handfull of guys using it wich is probably why I come off as such a cowboy. If dave doesn't have it he will find it.
Old 04-12-2007, 06:03 PM   #7
supramacist
Yo...., I spoke to Dave and he says no problem. If he doesn't have your mhg in stock he'll track it down even with you being .50 over. He said he had them in stock from 84 to 86 I think he said.
Dave Nguyen @ ext. 103
Old 04-16-2007, 04:20 PM   #8
Supra_87_mk3
Smile thank you
i really appreciate your help with my gasket and i am looking forword to building my car next sat... if i get the gasket in.. i dont know if i should go MHG b/c im not doing alot of boost prolly 15 pounds max until i tune it more.. im still mostly sotck until i fix the HG. Agree Or Dissagree Any Comments would help.
(turbo XS BOV. Intake, cat Back, front strut mount and coil overs.) looking for a boost controler and turbo timer.i would also like to eventualy get a stand alone system but im on a budget as of right now.
Old 04-16-2007, 06:45 PM   #9
supramacist
Wich MHG did you decide upon???
Old 04-17-2007, 04:12 AM   #10
Supra_87_mk3
Smile
thankyou dave was a really nice sales man and really did know his stuff. i didn't go metal but i did get a very thick gasket.. he said it was almost 2 MM (i beleve) i just hope it will work.
