Old 04-03-2007, 04:43 AM   #1
Getphazed
Getphazed is on a distinguished road
Default Error Codes 42 and 43
Im recieving these error codes can anyone shed some light on whats causin this?
Getphazed is offline   Reply With Quote
Old 04-03-2007, 05:24 AM   #2
dcrusupra
dcrusupra's Avatar
Code 42 - Vehicle Speed Sensor Signal
Diagnosis - No "SPD" signal to ECU for 8 seconds when engine speed is between 2,500 RPM and 4,500 RPM (7M-GE) or 4,000 RPM (7M-GTE) and coolant temp. is below 80* C (176* F) and neutral start switch is off.
Trouble Area - Vehicle speed sensor circuit, vehicle speed sensor, or ECU
Code 43 - Starter Signal
Diagnosis - No "STA" signal to ECU until engine speed reaches 800 RPM with vehicle not moving.
Trouble Area - Ignition switch circuit, ignition switch, or ECU
New Rebuild
My CarDomain
Old 04-03-2007, 05:34 AM   #3
Getphazed
Ya i got all that but what do they mean? Im drivin a 91 turbo w/5sp now i dont have speedometor cable hooked up cause needs to be fixed which i figured is 42 but not sure and i have no idea what 43 means by the description.
Old 09-14-2008, 09:57 PM   #4
carfanatic89
carfanatic89's Avatar
carfanatic89 is on a distinguished road
Can anybody tell me where the vehicle speed sensor and/or show me a pic of where it is.
Supra Engine Powered Dragster
carfanatic89 is offline   Reply With Quote
Old 09-14-2008, 10:16 PM   #5
Chambers
Chambers's Avatar
If its the one I'm thinking of then its on the back of the instrument panel, the TSRM should have something on it in the cruise control section.
Good luck.
"Stuck in the 80's"
Old 09-14-2008, 10:27 PM   #6
carfanatic89
I looked but no luck theres not a good picture of where it is. My ecu threw a code 42. and My speedometer quit working. Where does a ecu get a signal of how fast the vehicle is going. I dont have ABS, whats the purpose of this sensor.
Old 09-14-2008, 10:32 PM   #7
Chambers
Chambers's Avatar
Well if your speedo cable is broke then it wont spin the speedometer and then it wouldn't send the signal to the speed sensor, I could see how that could fool the ECU in thinking the sensor was bad.
I think the sensor is mainly for the cruise control. It should be labeld on the back of the instument panel.
Good luck.
"Stuck in the 80's"
