Old 04-02-2007, 12:58 AM   #1
marc
Default help plz
hey can any1 answer me this question... ive seen sum ppl put n/a cams into their turbos...how come?
and also i crashed my supra b4 i blew the hg and i think the frame is crooked now because the new bumpers does not aline and the lights and stuff have shifted...is there any way to correct this?
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
Old 04-11-2007, 04:52 PM   #2
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
the only right way to fix your frame is for it to be taken to a body shop and to be put on a frame rack where they will pull it to factory spec. its not somthing you can do in your backyard
Supra_87_mk3 is offline   Reply With Quote
Old 04-11-2007, 06:00 PM   #3
supramacist
supramacist's Avatar
Unless you have a big hammer.
Old 04-11-2007, 07:23 PM   #4
j3pz
lol @ big hammer comment
as for the cams, they do this because the na intake cam has a longer duration. longer duration = valves open longer = more air/fuel. i believe it improves the power in the mid range, but dont quote me on that, im not sure where it improves... also its only the na intake came thats different, the na and turbo exhaust cams are the same
Old 04-11-2007, 07:39 PM   #5
supramacist
I used to work in a body shop and seriously...., if they don't have a frame machine they will literally beat it with a hammer and possibley even heat it up with a gas torch and you don't want that at all.
