Old 03-28-2007, 02:10 AM   #1
ethan12510
ethan12510 is on a distinguished road
Default Fuses?
Where beside in the engine compartment are more fuses? thanks
ethan12510 is offline   Reply With Quote
Old 03-28-2007, 02:23 AM   #2
redmaro
Under your dash on the left side youll see a hidden door.
Right accross your brake pedal to the left youll see a little door(cover).
MK3, Auto, Turbo.
Old 03-28-2007, 03:33 AM   #3
plaaya69
plaaya69's Avatar
Wink
Also on the passingerside side their is a A/C fuse.
Old 03-28-2007, 12:29 PM   #4
ethan12510
i want to use my radar detector but the cig lighter dosent seem to be working. IS the fuse for that on the passengerside or the driverside?
Old 03-28-2007, 01:26 PM   #5
redmaro
On the passanger sider under the dash to the side.
MK3, Auto, Turbo.
Old 03-28-2007, 06:12 PM   #6
ethan12510
Default found one?
well i found the compartment on the driver side, is CIG for the cigarett lighter? but i cant find the fuse compartment on the passengerside?
Old 03-28-2007, 06:50 PM   #7
plaaya69
plaaya69's Avatar
You really do not need to worrie about the passingerside because their is only 1 fuse for the A/C and a CB for the A/C also.
Old 03-28-2007, 07:19 PM   #8
ethan12510
ok i wolnt worry about it . Now is the CIG labled Fuse the one i want? or is it another one? and what doses ATL stand for in the engine fuse box? Well i hope you guys can answer all my questions thanks
Old 03-29-2007, 09:48 PM   #9
ethan12510
Well i went out and looked an the fuse apears to be ok? I dont know> any ideas?
Old 03-30-2007, 09:07 PM   #10
dannydavi
dannydavi's Avatar
i'll go take a look at my repair manual on my next break to verify which fuse would operate that and let you know, but yeah probably the one labeled cig, and i'll find out the atl for you too
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Fuses....con-fused! SupraSaver87 Non-Generation Specific Questions 6 09-13-2018 07:47 AM
headlight issue, prolly fuses!!! help please? kingofyo1 MKIII Supra 4 10-16-2008 03:12 AM
fuses in fuses block supraman121 MKIII Supra 6 05-19-2007 04:09 AM
Alarm MICAHMOBERLY Non-Generation Specific Questions 5 08-27-2006 10:00 PM
Fuses - Where are they? mxbsuper MKIII Supra 3 01-30-2005 11:27 AM
