Old 03-27-2007, 10:41 PM   #1
D_Train
D_Train is on a distinguished road
Default where would I put a jack
Where should I put the jack if i'm going to burp the car? Whats a good spot that the car can support itself?
D_Train is offline   Reply With Quote
Old 03-28-2007, 06:49 AM   #2
j3pz
under the rearend or under the subframe, then there are jack locations also, one behind the front driver tire, front passenger tire, and one in front of the rear driver tire and rear passenger tire
Old 03-28-2007, 01:40 PM   #3
D_Train
To burp the car the front end has to be up i think. So my best bet would prob. be behind the passenger in the front and behind the driver in front.
Old 03-28-2007, 06:16 PM   #4
j3pz
im sorry i meant to say those locations are for jack stands. put the jack under the crossmember/subframe jack it up to desired height, then place jack stands under the formentioned locations. i just ran out to take pics
this is the crossmember/subframe where you put the jack
this is where the jack stands go
heres a close up of the front one. see the metal where you set it?
Old 03-28-2007, 06:17 PM   #5
j3pz
sorry for such large pics, gonna have to change the settings on my camera
Old 03-28-2007, 09:52 PM   #6
tone loc
tone loc's Avatar
what do you mean burp?
Old 03-28-2007, 10:29 PM   #7
D_Train
Awesome pics!
As for burping, do a quick search, you'll find a write up of it. IT basically gets the air out of your cooling system.
Old 03-28-2007, 11:30 PM   #8
JunkerMK3gte
JunkerMK3gte is on a distinguished road
just warm the car to temp . the therostat will open. take it to 1500 rpm for about a minute. bring it to idle and check your level.
JunkerMK3gte is offline   Reply With Quote
Old 03-28-2007, 11:53 PM   #9
ddmcse
ddmcse's Avatar
Cool
this will not remove the possible trapped air in the (TOYOTA SUPRA) coolant system
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 03-29-2007, 12:09 AM   #10
j3pz
air gets trapped in the heater car as it is higher than the rest of the coolant system. raising the front will make the coolant system about level, then running the car and heat will push the air out.
i think thats what it is. do a search for it, i believe its in the faq section
engine removal mizuboi MKIII Supra 11 06-10-2011 06:25 AM
new clutch thechori MKIII Supra 5 11-07-2006 08:37 PM
car weight? redmaro MKIII Supra 12 09-22-2006 11:44 PM
