Old 03-20-2007, 07:20 PM   #1
D_Train
D_Train is on a distinguished road
Default Overflow Tank
I ran my car on the freeway, brought it home, checked the coolant overflow tank and the fluid was in the middle of the tank. Is this normal after running the engine?
D_Train is offline   Reply With Quote
Old 03-21-2007, 02:52 AM   #2
mrnickleye
mrnickleye's Avatar
Wink
Depending on the driving, the coolant in the bottle will go up & down. But it should not overflow out of the bottle.
I keep mine about 1/2 full, and it stays there, cause I don't have any issues.
I might go into the mtns (like last Sun) and drive like a maniac, and I always stop and check under the hood before heading back home.
The level may be up, even close to the top sometimes, but then it will go back down after sitting for several hours. This is normal for these cars.
Slow Bubbles Into The Resevoir Tank Drag0na5h MKIII Supra 2 03-18-2008 05:37 PM
gas tank leak burton51m MKIII Supra 14 11-24-2006 06:16 PM
WAter not going back to raditor from recovery tank Help Jeff_5_7 MKIII Supra 12 09-15-2006 03:49 AM
WAter not going back to raditor from recovery tank Help Jeff_5_7 MKIII Supra 0 09-07-2006 02:05 AM
boiling overflow tank kewlcoconut MKIII Supra 9 01-22-2006 07:30 PM
