Old 03-17-2007, 09:10 PM   #1
boner1115
boner1115 is on a distinguished road
Default i cut my springs, i need help
so i was lowering my car by just cutting the springs, the front left spring worked perfectly, but the front right spring popped off of the shock. so i am not sure how to get it back on, i had tried to jsut force it back on but i cant get it on even so it keeps popping off. i was curious if any of you had done the same. oh bye the way i cut the bottem of the springs, and i only cut one 1.5 inches off. so anythign ideas will help. thanks.
boner1115 is offline   Reply With Quote
Old 03-19-2007, 08:30 PM   #2
grygst76
grygst76 is on a distinguished road
Buy springs already made for the car that are lowered, when you cut 20 year old springs you are asking for trouble regardless. They make you bottom out harder number 1, plus the spring is compromised from the heat or however you cut it.
Also the reason you cannot get the spring to stay on the support....
89 Turbo, no mods yet
5 speed mbc to 10psi
grygst76 is offline   Reply With Quote
Old 11-22-2009, 04:07 AM   #3
dupra87
dupra87 is on a distinguished road
Default help
u should have cut them at the top then u wouldnt have ad the problem
dupra87 is offline   Reply With Quote
Old 11-22-2009, 04:56 AM   #4
jdmmilhouse
jdmmilhouse's Avatar
jdmmilhouse is on a distinguished road
u should of cut from the top
jdmmilhouse is offline   Reply With Quote
Old 11-22-2009, 01:28 PM   #5
mirage83
Shouldn't cut them at all. Best fix is to replace the ones you cut with springs which are designed to lower the car.
Old 11-22-2009, 04:54 PM   #6
MA70-3.0GT
MA70-3.0GT's Avatar
Agreed, stock springs (or any springs for that matter) should not be cut as the temper of the metal can be affected by heat, as already mentioned.
Plus, and this is the one a lot of people don't consider, the spring rate (the poundage of weight required to compress a spring a certain amount) is worked out with the stress being divided between all of the coils, if you start removing 2 or 3 coils from a spring that has say 25 coils then you've effectively increased the load that has to be taken by the remaining coils by around 1/8th (12.5% or on a 1500kg car about an extra 175kg) & thus made the spring softer as well as shorter. 25 is a lot of coils to start with and the less coils that were on the original before cutting, or the more coils removed, increases this percentage considerably This increases the chances of bottoming out & also can mean that the springs are to all intents and purposes dangerously overloaded.
OK, on some less "finessed" cars you can get away with it because the working tolerances aren't so close (provided the MoT/DOT man doesn't notice), but on something that's already been tuned to give a sporty ride from the factory & potentially will be hitting 150+mph, there's not really much room for error, hence why companies make a lot of money selling uprated & lowered springs, because that's the only safe & legal way of doing the job.
Old 11-25-2009, 03:25 PM   #7
Peter.J
Peter.J is on a distinguished road
you could use a spring compressor. auto zone has a free tool rental service just be careful. you may have to remove shock/strut from car to complete the work. good luck!
Peter.J is offline   Reply With Quote
I need springs curtismoff MKIII Supra 5 03-11-2007 03:26 AM
Eibach lowering Springs: YOUR OPINION please sportriderseattle Non-Generation Specific Questions 0 02-21-2006 03:38 AM
lowering springs chase Non-Generation Specific Questions 2 06-15-2005 01:42 AM
