Old 03-08-2007, 03:45 AM   #1
frostburn
frostburn is on a distinguished road
Default BHG help plz
ok... im not sure if its blown or not... but definitly warped, when i push my car and get the engine heated then turn off the car it either steams out the hood right infront on the drivers side window, then when i start up the car again it shakes like its having a heart attack and then suddenly fixes... and revs to 1.1k idle anyone know anyways u could fix this problem, ... if not where i can get the head gasket fixed at a not to costy place.
frostburn is offline   Reply With Quote
Old 03-08-2007, 04:24 AM   #2
plaaya69
plaaya69's Avatar
Have you worked on a Supra before because If you know alittle about these cars you can probably try and do it your self as long as you have some standard tools and some knowlege about cars. I did my first hg on my Turbo Supra when I was 16 and that was the first time I really worked on a car and I feel that since I did it my self I feel much better knowing that it is done right.
If you take it somewhere then you will need to tell them not to torque the headbolts to 58FT LBS(That was the OEM torque which caused Supras to blow gaskets in the first place). You should get some ARP bolts and torque it down to 75FT LBS.
Also is your car overheating or do you have any codes?
Old 03-10-2007, 02:06 AM   #3
frostburn
no errors.. just purely overheats, and i wouldnt know the first step in changing a head gasket
Old 03-10-2007, 04:06 AM   #4
plaaya69
plaaya69's Avatar
Its too bad that I dont live more close to you or else I could have helped you out with the gasket. Maybe you should check the tsrm.
Old 03-10-2007, 04:38 AM   #5
frostburn
whats is the "tsrm" sorry i guess im more of a nooby than i thought.
Old 03-11-2007, 03:20 AM   #6
IHateHacks
IHateHacks's Avatar
TSRM= Toyota Supra Repair Manual
It costs around $130 to get your year specific version, or you can use the link around here somewhere for the '90 version (I think its for a '90?)
Old 03-11-2007, 05:04 AM   #7
plaaya69
plaaya69's Avatar
I would have to look for the tsrm link. If I find the link I will let you know.
Old 03-11-2007, 09:11 PM   #8
jfunez
jfunez's Avatar
look in the main page......its somewhere in the top or first posts....
Old 03-12-2007, 02:25 AM   #9
IHateHacks
IHateHacks's Avatar
Here she is. And it IS for a '90. (I knew it!)
There are differences between the years though. You can't buy TSRM's at the dealer, but if you ask them they will give you an 800 # for you to order it from.
