Old 03-04-2007, 06:43 PM   #1
abhattan
abhattan's Avatar
Default Need hlep with suspension problem.
Hey guys, I have an MK3 with TEMS. I purchased it without the TEMS hooked up and non adjustables in the front and in the back. THey are tokico blues and the rear are shot. I can't find the correct ones to replace it. I need it as soon as possible. Please someone help.
Old 03-04-2007, 06:50 PM   #2
damdog05
damdog05's Avatar
i believe tokico illumina shocks will work with tems, but research it first since im not totally sure
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
Old 03-04-2007, 08:09 PM   #3
Wink
It sounds like he's still not gonna hook up the TEMS. In that case, he should be easily able to find some replacement shocks.
"I" would go ahead and replace all 4 shocks at one time, because you want the car to be balanced well, and handle it best.
New shocks on only one end may perform differently, and cause some handling problems.
Old 03-05-2007, 01:29 PM   #4
abhattan
abhattan's Avatar
I don't have any of the motors for the TEMS and need a strut that will fit in there and work without the TEMS. What will happen if I put the TEMS strut without the motors?
Old 03-05-2007, 02:37 PM   #5
supraman121
tems struts are expensive for one thing i just replaced the front struts with kyb struts there good i just went to advanced auto parts and ordered them they were in the next day they should ask if you want the tems or not
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 03-06-2007, 01:27 AM   #6
old dude
old dude is on a distinguished road
I just replaced the struts on mine with the Tokico Illumina. They seem to work well with the TEMS but the first one was a pain to put on until I figured it out. I chucked the boxes or I would tell you exactly what they are. I used them with the Eibach lower springs. Tokico said they would work fine with the lower ride height but their life would be shorter
1990 grey Supra 1jzgte conversion
5 speed manual. APEX SAFC. Greddy Profec 2.
HKS blow off. 440 injectors. 3" exhaust. Large Innercooler.
Electric fan. HKS filter and inlet pipe. Greddy Defender
(not installed).Lsd Diff. EIBACH springs. Tokico adjustable struts to TEMS. Ceramic pads on drilled rotors.
Kumho front 225/40 ZR18 rear 265/35ZR18 on AZA wheels
old dude is offline   Reply With Quote
Old 03-06-2007, 01:58 AM   #7
abhattan
abhattan's Avatar
Does anyone know if the Tokico HP's(Blue) will fit directly in my car and are not TEMS?
Old 03-06-2007, 03:43 AM   #8
Talking Some other name brand drop ins
I don't know about Tikico, but just for info, here is 2 drop in shocks.
Front Sensa Trac Strut List $67.34
Part Number: 71214
Manufacturer: MONROE/EXPERT SERIES
Rear Sensa Trac Strut
Part Number: 71215
CARQUEST/KYB
F GAS SHOCK ABSORBER
GR-2 KYB 341069 $69.26
Rear KYB 341070
I strongly recommend top mounts while you have it apart.
Here is (samples)
Front Strut Mount List $72.020
Part Number: SM5160
Manufacturer: CARQUEST/KYB
Rear Strut Mount List $82.04
Part Number: SM5159
Rear Strut Boot Kit List $27.60 (Dust boot)
Part Number: SB107
Front Strut-Mate Mounting Kit $107.39
Part Number: 903994
Rear Strut-Mate Mounting Kit $99.77
Part Number: 903993
suspension problem supra_91 MKIII Supra 11 04-26-2007 03:04 PM
have some questions about 86-92 supra suspension jeremy_e87 Non-Generation Specific Questions 2 01-10-2007 11:53 PM
