Old 03-03-2007, 05:20 PM   #1
supraman121
Default Spark plug replacment
This might sound kind of dumb or mechanicaly impaired but how do you change the 2 center plugs on the engine? or how do you get to them to replace the plugs and wire im sure you have to somehow unbolt the intake? to get too it? and as easialy as possiable?
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 03-03-2007, 06:39 PM   #2
mizuboi
mizuboi is on a distinguished road
first we need to know if your car is a turbo car or not
my modifications
blitz nur spec catback exhaust, JDM 7m-gte, hks head gasket, arp bolts and studs, k&n air filter, Clutch masters FX300, hks SSQ bov, spearco intercooler, NGK iridium plugs
comming:
new fly wheeel
and not running
for sale
car parts for sale
misc. things for sale
stole it from sm
mizuboi is offline   Reply With Quote
Old 03-03-2007, 07:57 PM   #3
supraman121
sorry its a na 86
K&N Air Filter
Old 03-03-2007, 11:54 PM   #4
damdog05
damdog05's Avatar
damdog05 is on a distinguished road
you are going to have to remove the throttle body to get to them. its not hard...about 10 bolts and a few vacuum line and hoses. takes maybe an hour the first time you do it.
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
damdog05 is offline   Reply With Quote
Old 03-04-2007, 06:54 AM   #5
supraman121
10 bolts?
Did you remove the whole things i only counted 4 and i only had to undo 1 vacuum hose?
K&N Air Filter
Old 03-04-2007, 09:10 AM   #6
damdog05
damdog05's Avatar
there are the four(in my case three) brackets holding the throttle body to the engine. and then i took off the air intake connector, the y shaped tube that connects the throttle body to the intake manifold, which is held on by 6 more bolts. i realize i am using the term bolts for bolts and nuts, i should have been clearer at first but i wasnt thinking. i believe all the bolts and nuts can be removed with a 12mm socket
My cars:
Old 03-04-2007, 07:15 PM   #7
supraman121
i got it off i just dissconnected the body and i could get to everything thanks
K&N Air Filter
Old 03-04-2007, 08:03 PM   #8
mrnickleye
mrnickleye's Avatar
Wink
This is why I ask for the members to put the info in their signature.
Spark plug wires Quik Q carfanatic89 MKIII Supra 2 05-22-2008 01:46 PM
Broken spark plug! HELP! supraman121 MKIII Supra 2 10-02-2006 08:40 PM
new mk3 owner, spark plug galley full of oil!???? katillidie MKIII Supra 6 03-24-2006 05:09 AM
spark plug wires kewlcoconut MKIII Supra 2 03-19-2006 07:45 AM
stripped spark plug *c-town* MKIII Supra 3 12-20-2005 03:27 AM
