Old 02-28-2007, 04:42 PM   #1
kylesupraturbo
kylesupraturbo is on a distinguished road
Default Bursting Water Pipes
Hi there,
i have just bought my pride and joy a mk3 supra auto turbo but have a problem with her. The water pipes keep blowing off causing it to lose ALL the water. it drives good and temperature was at about quater but all of a sudden rocketed up and the pipe bursts. i thought it was the head gasket but it doesnt smoke, theres no creamy stuff on oil cap OR dip sticks
any help will be appreciated
many thanks
kyle
kylesupraturbo is offline   Reply With Quote
Old 03-01-2007, 02:11 PM   #2
IHateHacks
IHateHacks's Avatar
Sounds like "something" is overpressurizing the cooling system. Normal pressure should be around 13psi.
I would pressure test the cooling system and see if it holds 15psi, because it should with no problem. If they blow off at that pressure you need new hose clamps. If they hold fine, you probably have a blown head gasket.
You should also run a block test, only way you'll know for sure if the head gasket is blown/leaking. Very easy and inexpensive.
My supra didn't smoke, have "milkshake stuff" on the dipstick or oil cap, yet it still had a blown head gasket.
Old 03-02-2007, 12:57 PM   #3
kylesupraturbo
Talking Water Pipes Blowing Off
hi mate,
thanks for the reply. i had the rad taken out and had it pressure tested, they phoned me up and said that it only had 40% flow so that is 60% blocked. i think this is the cause of the pipes blowing off
cheers
kyle
Won't suck the water from overflow illusive38 MKIII Supra 7 05-24-2012 09:19 AM
Where the h--- is the water going??? illusive38 Non-Generation Specific Questions 1 05-27-2008 03:23 AM
Where the h--- is the water going??? illusive38 Non-Generation Specific Questions 0 05-26-2008 09:27 AM
Product Review: Cooleeze Pipes mkiiisupra Shops & Part Reviews 2 02-11-2008 04:30 PM
WAter not going back to raditor from recovery tank Help Jeff_5_7 MKIII Supra 12 09-15-2006 03:49 AM
