Old 02-27-2007, 05:38 AM   #1
88Tsupra
88Tsupra is on a distinguished road
Default how important is turbo timing
how important is turbo timing..i just have exhaust and intake...buh stock downpipe and exhuast...should i get the turbo timing and then get the downpipe and exhuast to flow better..or should i get the turbo outlet elbow then downpipe....den later headers..in that order..correct me plz if i should get one before the other...and oh n e body nkow cheap disibuters.
88turbo targa-white
original Pin Stripe
custom intake-Tenzo filter.....Momo racing seats and steering wheel...
apexi exhaust tip-custom 3" piping. Replaced with RSR GT II
NGK plug and wires
HID conversion head lights
HKS Turbo Timer Type-1 (in black)
Tial BOV
BIC DDP
88Tsupra is offline   Reply With Quote
Old 02-27-2007, 07:02 AM   #2
mizuboi
mizuboi is on a distinguished road
well as far as i know headers are not on turbo's
but as for getting your turbo to breath better i would say get a downpipe forst to reduce weight unless you are concerned about passing emissions in nazi california
as for a turbo timer its really up to you if you run you car hard i would suggest a turbo timer
my modifications
blitz nur spec catback exhaust, JDM 7m-gte, hks head gasket, arp bolts and studs, k&n air filter, Clutch masters FX300, hks SSQ bov, spearco intercooler, NGK iridium plugs
comming:
new fly wheeel
and not running
for sale
car parts for sale
misc. things for sale
stole it from sm
mizuboi is offline   Reply With Quote
Old 02-27-2007, 04:04 PM   #3
Jjona5
Jjona5 is on a distinguished road
All a turbo timer does is keep the car running after you cut it off to cool off the turbo so oil will not burn in it. If oil burns on the bearings in the turbo they wear out much more quickly.
Jjona5 is offline   Reply With Quote
Old 02-27-2007, 07:20 PM   #4
88Tsupra
i think ima just go with the downpipe...i dont care about passing...buh whas connect to the engine if theres no header
88turbo targa-white
original Pin Stripe
NGK plug and wires
Tial BOV
BIC DDP
Old 02-28-2007, 05:28 PM   #5
boogum7
boogum7 is on a distinguished road
Default exhaust
the turbo is what connects the exhaust to the block/manifold.
then the elbow comes off the turbo and then you have your downpipe.
headers come directly off the block because there is no turbo.
stock
boogum7 is offline   Reply With Quote
Old 02-28-2007, 10:49 PM   #6
88Tsupra
thanx..so ill just get elbow an downpipe and hi flow exhuast next after my new ngk wires and plug
88turbo targa-white
original Pin Stripe
NGK plug and wires
Tial BOV
BIC DDP
