Old 02-26-2007, 01:33 AM   #1
Jjona5
Jjona5 is on a distinguished road
Default ball joints
What is the process on changing the ball joints on an 88 supra? Do you change the whole A arm or can it be pressed in and out?
Jjona5 is offline   Reply With Quote
Old 02-26-2007, 02:54 AM   #2
supradaddy0803
supradaddy0803's Avatar
It is actually easy you basically look on the back of the spindle and you will see a castlated nut on the bottom and the top the one on the bottom is the one you are looking for. Pull the cotter pin out and loosen the nut heres the fun part pop the stud out of the spindle and remove the three bolts from the lower A arm and the whole assembly slides out. I looked all over when I got ready to do mine they dont even actually sell ball joint to be pressed out the assembly you buy is the one you need.
Old 02-26-2007, 05:10 AM   #3
mrnickleye
mrnickleye's Avatar
Wink See This in TSRM.
http://www.cygnusx1.net/Supra/Librar...tion=FA&Page=1
TSRM is your Supra Bible. Study it for the good word !!
Old 02-26-2007, 06:36 AM   #4
Jjona5
Default hmm
So the upper balljoint is just a 300-400 dollar entire assembly then...sigh.
Old 02-27-2007, 03:12 AM   #5
mr.w
mr.w is on a distinguished road
It was pretty easy to do, I only paid $75 for my ball joint at autozone. Definatley didn't cost $300-$400 dollars.
mr.w is offline   Reply With Quote
Old 02-27-2007, 03:19 AM   #6
Jjona5
Were you changing the upper or the lower? The lower ball joints look like they can be bought by themselves...the upper looks like it has to be bought as an entire assembly
Old 02-27-2007, 03:47 AM   #7
mr.w
Oh I did the lower, I didn't realize you were talking about both.
Old 02-27-2007, 03:50 AM   #8
Jjona5
Well the upper ball joint on the front passenger side seems to have some play in it and my suspension is about to be basically brand new. Poly bushings all the way around, bigger sway bars, eibach springs, and bilstein shocks(amazing fyi just amazing).
Old 02-27-2007, 04:41 AM   #9
mrnickleye
mrnickleye's Avatar
Default I have the catalogs on my hard drive
Not sure yet how old these prices might be now, but.....
The upper arm(w/ball joint) Part #48610-14010 Rt side, #48630-14010 Lft side, is approx $250 US. each available at Toyota only.
The lower ball joint wears out much sooner.
It is approx $70 at Toyota.
Today at Carquest: Yrs 87-92, #CH K9521 BALL JOINT List $105.40.
Rt or Lft side, same part #.
Old 02-27-2007, 05:19 AM   #10
88Tsupra
88Tsupra is on a distinguished road
i went to auto zone just today and the lower ball joint is only 56 buh they didtn have the upper...just watch out toyota dealer parts are expensive i ask for the price on a outter Tie Rod it was freaken 106 bucks gdamn
88turbo targa-white
original Pin Stripe
custom intake-Tenzo filter.....Momo racing seats and steering wheel...
apexi exhaust tip-custom 3" piping. Replaced with RSR GT II
NGK plug and wires
HID conversion head lights
HKS Turbo Timer Type-1 (in black)
Tial BOV
BIC DDP
88Tsupra is offline   Reply With Quote
Lower Ball Joints - Checking here first Grandavi MKIII Supra 3 09-20-2008 04:04 AM
power steering problem 3.0trd MKIII Supra 12 06-24-2008 01:17 PM
Tie Rods & Ball Joints mrnickleye MKIII FAQ 1 03-10-2007 04:50 AM
Tie Rod End and Ball Joints!! KrnSupra2307 MKIII Supra 6 02-27-2007 11:01 PM
